Watham 6/0 vs. 6/0-D
Anybody know the difference in these?  I have a 6/0-D (military watch) that needs a new balance staff.  I see some 6/0 staffs on Ebay (#26106) but not sure if it is what I need.  No help on Ranfft site.
Edited by LittleWatchShop
corrected 3/0 to 6/0 in body
Usually for American pocket watches I looked up the serial number of pocket watch database. Then I get a model number so I can look up the parts for that model number if you're lucky on the pocket watch database site that list the parts saving you having to look in your books.
Then several problems with just having a staff number. Typically with American pocket watches in most cases you also have to have a pivots size as you can have one staff number for several pivots. Or there's an Elgin that you can have a whole bunch of variations for one staff number beyond the pivots size for the same number.
So once you get a staff number then I look on my staff listing which I've snipped out the section for you. You'll actually see the number that you have listed but?
The other thing that's viable to do is to measure the staff that's currently in the watch. To verify that it's measurements agree with whatever you think you're going to purchase. Then before putting in the newly purchased staff you do have to verify that it's measurements agree with whatever you think the measurements are. Otherwise unpleasant surprises will happen later on and their lot easier to fix when the staff is not in the balance.
If you look the list I have below you'll notice that there is a reference to a G.I. watch and the staff number is slightly different and some of the dimensions are slightly different. This is why you need to measure what you have to see how it compares to listing and pick one based on that and hope we'll be right.
This is useful.  It comports with what I see in the CE Marshall catalog pretty much.  The only unknown is the pivot size.  I will measure it.  I dont understand why the two different pivot sizes have the same part number.
American pocket watch balance staffs defied logic. For instance my favorite staff at least for a lecture purposes is 857. I'm attaching the section of the book on that. So we have four different physically sized staffs and then you have the pivots size difference. Which gives us 14 staffs for the same part number. Then if you have an Elgin parts catalog and you are order a dozen of them back when you could if you didn't specify the pivots size they would send you a variety of sizes. But for these variations you would build a specify something beyond just the part number like to be old-style new style or there is some letters that get tossed in.
Then I had another listing of military staffs and it looks like list I have above has both of them.
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
