Watham 6/0 vs. 6/0-D
Anybody know the difference in these?  I have a 6/0-D (military watch) that needs a new balance staff.  I see some 6/0 staffs on Ebay (#26106) but not sure if it is what I need.  No help on Ranfft site.
Edited by LittleWatchShop
corrected 3/0 to 6/0 in body
Usually for American pocket watches I looked up the serial number of pocket watch database. Then I get a model number so I can look up the parts for that model number if you're lucky on the pocket watch database site that list the parts saving you having to look in your books.
Then several problems with just having a staff number. Typically with American pocket watches in most cases you also have to have a pivots size as you can have one staff number for several pivots. Or there's an Elgin that you can have a whole bunch of variations for one staff number beyond the pivots size for the same number.
So once you get a staff number then I look on my staff listing which I've snipped out the section for you. You'll actually see the number that you have listed but?
The other thing that's viable to do is to measure the staff that's currently in the watch. To verify that it's measurements agree with whatever you think you're going to purchase. Then before putting in the newly purchased staff you do have to verify that it's measurements agree with whatever you think the measurements are. Otherwise unpleasant surprises will happen later on and their lot easier to fix when the staff is not in the balance.
If you look the list I have below you'll notice that there is a reference to a G.I. watch and the staff number is slightly different and some of the dimensions are slightly different. This is why you need to measure what you have to see how it compares to listing and pick one based on that and hope we'll be right.
This is useful.  It comports with what I see in the CE Marshall catalog pretty much.  The only unknown is the pivot size.  I will measure it.  I dont understand why the two different pivot sizes have the same part number.
American pocket watch balance staffs defied logic. For instance my favorite staff at least for a lecture purposes is 857. I'm attaching the section of the book on that. So we have four different physically sized staffs and then you have the pivots size difference. Which gives us 14 staffs for the same part number. Then if you have an Elgin parts catalog and you are order a dozen of them back when you could if you didn't specify the pivots size they would send you a variety of sizes. But for these variations you would build a specify something beyond just the part number like to be old-style new style or there is some letters that get tossed in.
Then I had another listing of military staffs and it looks like list I have above has both of them.
    • Yes: that's it exactly, right down to the break in the spring!!
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
