If an 18000 balance complete were installed instead of the intended 19800 ? ... (Seiko 6216A)
There are a lot of posts throughout the forum about screwdrivers and everyone has their favourites. I've never had a problem with the Cousins ones of their tweezers. https://www.cousinsuk.com/product/value-screwdriver-sets-wooden-cases https://www.cousinsuk.com/product/cousins-swiss-style-sets-rotating-stands And these are the blades. https://www.cousinsuk.com/product/cousins-swiss-style-flat-stainless-steel?code=S57453
So everything points to the 20208 being correct. Is this what yours looks like and how does it compare to the original. Photos as always help a lot.
By nickelsilver · Posted
Hmm, well, using the faceplate and boring with the slide rest is I would guess an order of magnitude more accurate than simply drilling or reaming. So in a watch, that makes a difference. The project I mentioned above had arbors like 0.70mm long, with large diameter parts attached, so any misalignment of the jewels would cause a large tilting error of the part.
