I want to replace the six (6) tiny screws on the back of this Cartier quartz watch.  Does anyone know where I can buy new ones at a modest price?  I will change them when I change the battery.  If anyone knows where I can buy a new seal at the same time then that would be a bonus!
Ladies watch
Cartier Quartz
Must de Cartier 21
Red crocodile skin strap (Made in Austria CMK – Cartier KD40ZF02), silver and gold face with red numbering, blue hands, blue sapphire jewel winder
Swiss Made
Water Resistant 1340
PL 22051
Hi paul,
 There is always some dirt residue round the backplate of used watches, so cleaning round the back prior to removal is always a good idea, a used tooth brush will do, a spec of that dirt falling inside the case as you are removing the backplate can find its way into the movement causing issues.
Best wishes
Joe
2 hours ago, Nucejoe said:
Hi paul,
Best wishes
Joe
Yes, I have an old carbon fibre toothbrush - very fine bristles!  I did another Cartier earlier with six tiny screws - used the toothbrush and some IPA sprayed on the back - cleaned up really well so I could get purchase with the 1.2 mm screwdriver.  You're right those screws get covered with dirt!  Wanted to get new screws for this watch though as I think they've been chewed a bit (wife previously sent it to Cartier each time for a battery change - said she must have spent well over $1,000 on battery changes over the years - no more - will do it myself!).
3 hours ago, clockboy said:
Cousins is a good source they have a really good selection
Is that cousinsuk.com?  Thanks for the tip - I'll have to have a look!  Thanks again!
  • Similar Content
    • Funny I should come across this particular thread because I have a hairspring that I’ve just knocked the collet off!! It was too loose on the balance wheel and I was trying to tighten it (of course I failed!).  So I’m looking for a new balance myself. The hairspring is in quite good shape but obviously doesn’t have a collet now, so I don’t know if you’ll be able to use it. I wouldn’t dream of trying to refit the collet myself because I know exactly what would happen!! If I wanted to refit the collet to the hairspring (assuming I can find the original as it’s on the floor somewhere!!) where would I find a taper pin small enough? As some of you may know, this whole thing is tiny!!
    • Thank you. No value to me, and I guess not much value to anyone else either - just practice fodder as far as I see them. Ingersoll might make a nice watch to wear if I manage to service it. Benrus, I suspect, is too far gone in terms of case and dial - no cheap ways of getting them to decent looking condition? I wonder how these old movements compare to modern Chinese ones? Probably not favourably, even if there's nothing broken in them? Progress moves on? I've got an old Slava that I'm quite attached to, so I won't be learning on that one.
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
    • Welcome to the WRT-Forum! Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
    • In writing "shimming the staff" I was alluding to the idea trailed in the above referenced thread of inserting a hair along the staff which, as the discussion there covered,  could result in some eccentricity. By making a (more or less) complete cylinder I was hoping to avoid that problem. Don't tell anyone, but needing a very ductile metal to do this by manipulation at such a small scale, I used a piece of an empty Tomato pureé tube! It occurred to me that the material's ductility(?) would also put less stress on the RT in forming a sufficiently tight seal. Anyway, that's how I avoided the temptation to use glue. No doubt your punctuational response to this confession will be "!!!" !
