Sony Mz-R30 Minidisc Walkman Player/recorder
Actually, it looks like the crown just unwound. Try screwing it back in. -
I seem to remember a little depress divot right around here somewhere. Anyhow you now need to order another stem so lets start by finding the movement code on there -
That is not a split stem. Cheap watches do not use split stems as that costs money. The correct way is to pop the back off and release the stem. The battery is also accessed via the back. When you get your caseback knife, practice on the old watch first. And another advice I almost forgot to give is... if it's that difficult to open, it'll be difficult to close. You'll need a caseback/crystal press. -
Thank you for your help. I had to pop the bezel off. It was easy... then I tried to loosen the stem. I pulled on, apparently to hard, and I think it broke. had the tilt the guts out and slide out the stem. I think I am going to find a similar watch and swap the dial. I put a hurtin' on that case and the crystal had a crack. Live and learn. I appreciate all of the help you provided.
