My Garrard Automatic has developed a loud click at almost every turn of the crown when hand winding. It appears to collect power ok though and also auto winds correctly and keeps working whilst wearing. I have taken the rotor off but have not been able to locate the source of the problem. Any assistance as to where I might start looking would be appreciated
I'd be tempted to take the winder module off too, to see the click, rachet and winding wheel. You not only  have eliminate the parts you removed but might even see the fault starring at you, also wind through rachet wheel, that eliminates quite a bit for the least.
Its a process of elmination, next I guess is checking under dial.
Good luck
Does your watch have a caliber number? Then it almost looks like is a number under the balance rim that would be helpful if there's a number there? We might bill a find a tech sheet perhaps.
Then we can guess because we can't see the automatic mechanism so that probably has to come off. It may be that the reverser wheels have gotten sticky with time but that's just a wild guess. Also the other problem with automatic watches is often times they did not use jewels in critical locations and the holes where out to get oval. So basically this is exactly as mentioned above problem solving and you're going to have to take the automatic mechanism off. Then carefully look at all the wheels all of everything and you should build figured out hopefully
It's always amazing what you can find online if we take the movement number and the name they come up with the links below both of which suggests that the movement is based on  ETA 2783. From that we can a parts list.
https://antiques-atlas.com/antique/gents_unusual_1970s_silver_wrist_watch_garrard/as170a7214
https://www.birthyearwatches.com/product/1974-garrard-9k-gold-automatic/
496_ETA2750,1,2,6,4 ETA 2783.pdf
Thanks JohnR725 for that connection... I must say the gold Garrard which is the same as mine seems rather expensive at £449. I sold 2 of mine last year at less than half that price. But I suppose that is why they stay on sale for month after month after month
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
