My Collection.
I thought I would post a shot of my entire collection of watches and pocket watches. The picture is not great but hopefully it conveys what my ethos on collecting watches is which is diversity. I love all forms of horology and can get as passionate about my humble Timex easy reader as I can about my Air King for they all mean something different to me.
I hope you like the watches and if you want to see better shots of any then let me know and I will post better pictures on this thread.
So! Top row are: John Forrest Lever Fusee Sterling silver pocket watch made in 1894, Next to it an Omega Canadian market pocket watch in Nickel silver made in 1916
Main row left to right are:
Archer Watches Sterling ( Hand made in Canada)
Timex Easy Reader
Bulova Accutron (1971)
Rolex Air King (114200)
Birks ( Canadian equivalent of Tiffany's or Mappin & Web) branded Fortis Manual wind (circa 1970's)
Cathode Corner Nixie watch (As worn by Steve Wozniak of Apple Computers fame)
Sekonda manual wind (made in the Poljot #1 factory Moscow late 1970's)
Cartier Tank (mid 1970's)
Bulova American Clipper (1937)
Election Chronometer (Mid 1930's)
And last but not least, Casio G shock mudman.
Hope you like my humble collection. I get a huge amount of satisfaction wearing all of them and new or old they all get lots of wrist or pocket time!
Thanks for looking.
Thanks Roger, you know the craziest thing? I completely forgot the other three! I will add photos later but I also have a Tissot T touch and two Citizens, a 2100 and an all black stiletto! You know when you have too many when you forget to add three lovely ones!
What a lovely diverse collection.
Your ethos is very similar to mine, I too have a lot watches with different movements and looks. I'm just amazed at how many variations on a theme that there is in horology, I particularly like chronograph movements with added complications. That said, I like the outside of a watch to be uncluttered and easy to read.
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
