Seiko 6138 - Quick set date doesnt work
Khan
Hi
As per video, the quick set doesn't shift the date wheel but turns the wheel for day wheel. Feels like there is not enough force in the wheel at 3 o clock that turns the date wheel. The two top plates levelling the date disc are not overtightened. The date changes when turning hands 24 hrs or by moving the disc manually by finger without resistance. Any ideas?
Thanks
Edited by Khan
Hi Melt
Thanks for the tip. I have actually seen those two plan designs of the upper wheel on the so called "wheel lever complete" (the one I have and the one you referred to on image). From a side view, that date changer wheel system consists of two almost identical wheels and the wear is in between these wheels in a way that the date disc is slipping through and doesn't shift. So I have to order a new. These are not easy to find.
Edited by Khan
11 hours ago, Khan said:
Hi Melt
I guess you could fill the gap with a chemical metal......worth a try if you can't find a replacement.
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
