Landeron 47: Wrong regulator arm?
Hoe
Dear watchmakers
I just serviced a Landeron 47 which is in good condition over all. But I could not get a decent result on the time grapher (watch runs too fast, huge beat error). After digging deeper I found the following.
The regulator arm pin on the balance cock is too far away from the centre of the balance in relation to the hairspring pin fixed on the balance cock. This causes a lot of distortion of the hair spring when everything is assembled. I guess someone in the history of this movement upgraded the balance setup with an Incabloc and used a regulator arm that does not fit the dimensions of the hair spring (?).
Furthermore I noticed that the pin’s location on the hair spring is somewhat wrong. There is a long overhanging section of spring. The hair spring itself is fine.
What are your suggestions?
  • replace wrong hair spring (probably not)
  • manipulate the hair spring: shift the pin to reduce the overhang and to reach the regulator pin (not sure if I am capable to do this)
  • replace the regulator
  • downgrade the Incabloc to the original non-shock proof setup
  • Others?
Best wishes
Hi,
you can do as proposed by AshF, but a slight bend at the marked spot will center your hairspring:
It will move the collet at right angle to the line spot - hs center.
Why do you suppose  an original non-shock? How does the jewel in the plate look like?
Frank
Your third picture shows stud sitting at the begining of the TERMINAL CURVE( right after the bend), whereas it should be at the end, "end of hairspring"  Just like ashF shows.
Mount the stud in stud hole of the adjustment arm.
Unpin the hairspring.
Thread the hairspring through stud hole all the way to the end of hairspring.
Re-pin.
You have a good terminal curve already, minor manipulation like this is routine.
Shock system, regulator arm and all other components are the right type. One you pin the stud at the end of hairspring, all will fall in right place.
The micropin( hairspring pin) doesn't look in best shape, replace or sharen its tip for reinsertion into stad.  Do you know how to sharpen a micropin?
    • Just missed it! I have a donor movement on its way. But thank you for the offer--I'll let you know if I need anything else.
    • My latest. Timex 2465. Replaced the crystal, caseback gasket and spring bars. All in less than $5US. Added a gray NATO strap I already had in stock.
    • I have some Gruen 510's in my donor pile if you need parts.
    • I've been intrigued by everyone's input here...so I decided to give this a shot. I bought the"typical" Pearl watch-machine basket and trays, for about $65. The trays are good,..the housing is a nightmare ! Thought it would take the mixer off my bench at anything above about 200rpm. The housing is cast of course,..and it's not "true" at all...so the harmonic vibration was insane. So,..I bit the bullet and bought the Elma housing and top. Not the baskets though, as the Pearl one's fit the Elma. Saved a bunch there. The basket and lid came to about $80 with shipping. The opening in the Elma top is 8mm, and the shaft that came with my stirrer is 6mm. I bought a piece of steel tube, 8mm O.D., and 6mm I.D. Cut off about an inch of the tube, and drove the rod into it. Gives a really snug fit.... Lightly champfered the leading edge of the 8mm section, then lightly tapped it into the top of the Elma lid. Spins like a dream now So... I have about $240 total into this including jars and steel mesh for the wave breakers   I'm pretty happy Best to you all   Randy
    • Still haven't gotten around to getting stems or screws, but I did make my first attempt at polishing a case. I just used a soft mop and rouge to reduce my odds of ruining them, and I think they came up pretty nice. Also gave the crystals a polish on the same wheel while I was at it. They were both very badly scratched up. The one on the left is fairly beat up, but it'll still make for a decent presentation.
