I picked up a Wyler Dynawind with an ETA caliber 2375.  It has a broken setting lever spring for which I have sourced a replacement.  However, it is also missing a split stem male and female and crown.  Where can I get the right stem?  I am a newbie.  Do I have to make one?
Unless you fancy a challenge it's worth looking at the websites of the usual parts suppliers first. The Resources page you'll find a link to at the head of this forum is a good place to start.
I can see for instance Cousins has both male and female stem parts listed. I'm sure other suppliers closer to your neck of the woods might be able to oblige too.
Also a good tip to a newbie is not to focus exclusively on the movement model you're specifically dealing but be aware of models in the same family. In your case http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&ETA_2375 will list other members of the family. Often you'll find that parts are listed against the first member of the family ... so that's the ETA 2370 in your case. A quick ebay search on 'eta 2370 stem' brings up for instance https://www.ebay.com/itm/ETA-2370-watch-movement-part-404-female-split-stem/132105059577
With these breadcrumbs I'll let you take over...! ?
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
