Hello everyone!
I have an Invicta with a Ronda 7003.L movement in it on my bench. I removed the stem by pressing the release to reattach a marker on the dial. That went well enough, but now as I am putting the stem back in there, it doesn't want to go in all the way. It will click in, but it acts as though it is in position 2, where it adjusts the hour hands. It will not move in either direction, into position 1, or further out unless I push the stem release. Any thoughts on how to get this back in?
Thank you!
Riker
Edited by ItsRiker
Sometimes adding some rotation can help stems slip into place.
However if it really wont engage properly... Looking at the service sheet and going off of previous experiences I can only guess part of the setting lever mechanism has slipped out if place.
very difficult to access on this movement, most of it is dial side beneath a lot of calender work etc.
it may be worth a look top side as its relatively easy to reach it that side, but theres very little there to see or play with that might help you.
Shoot. Thank you for the information! I'll give it a try with some rotation, but I fear you are correct.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
