Apart from using very expensive tools, can anyone suggest an alternative way of replacing a balance staff on a pocket watch?
The only way really is to use is a staking set/tool. To remove the old staff there is a tool (see pic) that fits into the staking tool which is spring loaded and when depressed brakes the rivet of the balance. I used to use this on pocket watches so I know it works really well. If you have not got these tools then I would not attempt. The other way is to find the same movement on eBay & swop the staff & balance.
Edited by clockboy
As Clockboy said, you will require the correct tools, you will also require knowledge and a delicate touch. There is no easy fix for fitting a balance staff. :(
Edited by Geo
Thanks, both, for your replies.
I've thought of another possible answer.
Amongst all of you experienced people out there, there has to be someone that has the knowledge and equipment to replace the staff on my behalf.
So, for a fee, (Not talking about a holiday for two in the Bahamas!) is there someone that would be willing to do this for me?
If a donation to a charity is preferred, that's fine.
All costs involved (including risk) will be my responsibility.
The new staff should, with a bit of luck, be with me tomorrow. (March 11th)
Well...............!
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
