My worry about these is the amount of oil and what sort of oil.  Given that I buy small quantities of Moebius oil I am loath to empty a bottle into an auto oiler.
Then there is the question do you buy several for different oils then label them.
Its too much of a carry on.  However, I keep some cheap Anchor brand oil for the occasional scrap movement I want to play with and it would probably be ok for that so I might try one - the jury is out.
Cheers,
Vic
Vic,
I would imagine you'd have to buy several different oilers to keep from cross contaminating them (Moebius is too expensive to risk). I inherited a few very old auto-oilers and haven't touched them yet for just that reason.
I think it would be great  When you put expensive oil in the oilcup it always get contaminated with something . Hair or dandruff :) dust And then i have to clean the oilcup from old contaminated oil . If i had it in a auotoiler it wouldn't  get contaminated from anything and i would get just so much oil i need on the jewel . Maybe i will only need it for the 9010 oil . It can stay in the oiler for 6 years . I will probebly buy myself a nice Bergeon oiler someday .
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
