Hello All;
I just received a new watch with Seagull ST1612 (21,600bph) movement. The movement has positional errors, that's to say an amplitude from 210 up to 272 degrees, a beat error between 0.0 and 0.6ms and a daily rate varying between -18 s/d and +12 s/d in the different positions. The power-train seems to run smooth as the timegrapher-lines are in each position straight.
While wearing, luck will have it that the watch gains 2 seconds in 24hrs !
Of course, it's a cheap movement and on average it seems to runs very decent indeed. I may leave it for a while to see if things improve during the "break-in" period, but knowing myself there will be a day that I will tear it apart to see if I can improve on the numbers and make a "walk-through" for the forum (has been a while since I did the last one) :)
The movement is predominantly a clone of the Miyota 8215 but it has a Seiko style auto-winding "Magic lever" system.
Most likely it won't be that hard to service the movement, but just in case, or for future reference, it's always nice to have a manual .......
Anybody a manual with exploded views?
Hope to hear .... :thumbsu:
Edited by Endeavor
Chinese makers don't make any spare parts  (but the stem) or technical documentation available. Sometime, as in this case, the casing drawing can be found online.
I've found some dimensional information on the net, but sadly no further additional info. Ever so more reasons to do a walk-through about this movement in the (near?) future :jig:
