Half Hunter pocket watch conversion
geeboo
I bought a vintage English half hunter watch, left photo (shoulder lever set time at 2 o'clock), I want it converted to a wristwatch & need to weld a wire lug about 14mm wide (~1.5mm wire), repair 1 broken hinge & shorten the sleeve (crown tube) length to make it closer to the watch (right photo). Can any members here do this type of job for others ? Or Do U know whom can do that for me ? I am really finding difficulties in Hong Kong to find someone to do that.
Any help is greatly greatly appreciated.
Tks
That is typical jeweler's work, not watchmaker unless one is specialized in that. Maybe that can help you finding someone locally.
Well...I have mended broken pocket watch cases.  I can braze silver and rebuild broken hinges, and fill cracks well enough to make them vanish.  I suppose I could do everything you require.  But I could not do it very cheaply.  To shorten the pendant and the stem would require precise measurements of course.  Repairing the cover hinge is not hard, but it is also something that must be done right, and be correctly alligned.  And if the lugs are going to be silver, they will need to be coin silver or they will need to be somewhat thick, to be robust enough.
But I regret even thinking about it.  Pocket watches are a passion of mine.  I repair them, movement, case, and all, getting them looking and running beautifully.  And that demi-hunter watch is a beauty.  For me to do what you ask would feel too much like butchery.  That said, while I think even WWI trench watches are rather cool, I wouldn't want to make one, least of all from a watch like that.  I am not your man, I'm afraid.  It is your watch, with which to do as you choose.  It is my prerogative to choose what work I will take on.  I do hope you find a master who will make real art from it.
    • I've been contemplating getting one of these for some time now, after working on a few spring loaded centre seconds pinion movements. It's not an absolutely necessary tool to have, hence the procrastination.  Then it hit me, all I need is a flat base with a screw in it. So I scrounged around for something suitable and ended up with this. This is some rubber thingy that is  supposed to stop furniture with casters from moving around. In fact, any flat material with sufficient thickness to hold the screw in the centre would do.
    • I think your axes are mislabelled here. They need switching around.
    • @clockboy Thank you for the response.
    • @Knebo Thank you for the detailed response and reminding me. I went back and introduced myself. That's really good information, for 15xx it should be similar. Will dig deeper into that.   Yes I mean that. Attaching some pictures. New to shooting through a loupe so pardon the quality. I don't quite get the strength point, could you elaborate? Seeing the punch used for the job, it should limit the highest point of the metal being pushed, Maybe a worn out punch?       I haven't checked the axle will do that, but thee watchmaker told me that the 9'o clock side has been over-polished and the caseback is sinking on that side which is causing the issue. Armed with this knowledge, I will investigate both. The Picture would certainly suggest that plus the Intense pitting (wrist perfuming habit of my family) might be contributing to how the caseback fits.      Thank you again, I have made a checklist and will be investigating all the points you mentioned.   Rolex told me that they will replace the dial and bracelet so I didn't go that route. Its an independent watchmaker, and a very well reputed one in online and offline collector circles. I have seen his work and got work done from him before, this is the first time something like this is coming up. Maybe he is getting lazy in sourcing good parts. lol.
    • 😞 I hate the heat, i work outside in winter in a t shirt .
