1960s Seiko ebauches
Hi all, lately I've been coming across a number of movements based on Seiko ebauches transplanted into 1960s Orient watches. One of these movements was a Belforte 12F 4B, based on the Seiko 7625 ebauche.
My most recent Orient has stumped me as the movement has an Orient rotor identifying it as a Cal. 1931 with 19J. It's unlikely to be a 1931 as it has a balance cock rather than a balance bridge, it doesn't have the combined barrel and train bridge plate that Orient uses, and I can count 23J rather than 19J!
It looks like another Seiko 7625 ebauche but with a quick-set date pusher, and also it's most notable feature, 4 jewels on the day wheel (which I suspect are mainly there to up the jewel count).
It could be a Belforte but I've not found any examples on google with 23J, although there was one with 25J that had a date pusher.
Has anyone come across one of these movements before? The reason for finding out is mostly academic - I'm just curious to know what this would have started life out as. It's being used as a practice piece to develop my servicing techniques, and eventually a proper Orient movement will be sourced for the watch it came out of.
Also I think I've got all my facts straight regarding my research into these movements but please correct me if I've got anything wrong ^_^
Cheers,
Richard
Thanks for the replies, it's more than likely to be a frankenwatch as the dial printing gave a third opinion for a jewel-count (25J)... Still the base movement must have come out from something.
I'll get onto SCWF to see what the folks over there think. Cheers.
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
    • I did try that last time Rich , i traced the image from the Bestfit book which is the actual size. But its more difficut to cut the shape from paper than it is to grind the steel to shape. This way is pretty easy and the final shaping is done when fitting the part. There are a couple of things i will do differently next time, clamping the 2 pieces together with a drill press will help to hold while scribing the shape in. This was a bit tricky having only one hole, if using the pins and cork the drill size needs to match the pin diameter so there is no movement at all from the template. This movement hasn't finished frying me yet, damaged thread in the plate crown wheel hole and two rubbed in cracked jewels, thats gonna be much more fun.
    • 👍 Whats not to follow OH ?  You're every inch a pro and a true gent, i always enjoy reading your answers even some of the clock stuff that i dont have a clue about.
