How to deal with old gold plated case?
Hey guys. I just found this lovely Longines 817.
I love the dial but the original gold plated case is a little bit oxidized (I dont know if that is the case? Anyway it does not look shine), I dont know how to gold plate a case and I certainly wont do that. Polishing the case will ruining the gold color of the case and I'm not sure it's a brass case or a steel one. Does anyone know how can I restore the case? I dont need it to be super shine and sharp. I want to keep the 'vintage' look of it but I want it to look clean without dark brown color. Thank you!
The bezel ring and the crown looks like they been gold plated but the rest of the case looks suspiciously like an alloy, maybe brass. You probably can see what the case are made of by popping the case back off and there Longines usually have the data stamped, must say I never seen that case style on an 817 before either.
Anyhow think the polishing cloth @Rocket suggests is the way to go with softer metals.
Yeah will do. I just receive the item. The price is low. It only costs me $60. The movement it's real for sure, I didnt check the rest. However I dont think there's fake retro Longines. As for the case back reference number. It's 18892533. I think I will disassemble the case and deal with the bezel and the rest of the case respectively. For the brass parts I think some bushing and polishing should be OK?
Just a good clean and polish should be OK.
Your number is the serial number and inside the back you will then see a different number which is the case style.
The numbers looks like this.
1131 817 18k Gold (L817.4)
1132 1 817 18k Gold (L817)
4129 817 18k Gold-Plated (L817)
4131 817 18k Gold-Plated (L817)
6064 817 18k Gold (L817)
Inside your case back I think you should see the Longines logo and the numbers 4131 817.
it's 4131 3 817.
从我的 iPhone 发送,使用 Tapatalk
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
