New to the hobby
I've always liked pocket watches and have bought a few over the years.  I've had them serviced and they run well, but I've been thinking that I could probably do so myself.  I've watched a number of youtube videos and it seems possible, but I"m sure like anything, once I get into it I'll find it isn't as straightforward as it first seemed.  Anyhow, I'm about to gather a few tools and I think I'll buy a cheap movement from ebay and jump in.  Looking forward to interacting with you fine folks.
Greg  - Melbourne FL
there are several things you can start with broken pocket watch movements that you have no intention on fixing so you can practice taking apart and putting back together. brand-new Chinese movement preferably pocket watch as it's nice and big. what makes the Chinese pocket watch movements nice to practice on their cheap so if you break it which it probably will it's not a big expense. As you've already noted casually on the outside watch repair looks easy. So if you take apart your functional Chinese pocket watch and it isn't functional afterwords maybe it's not quite that easy. That makes it a lot easier to see starting with a running watch ending with a not running watch. Versus starting with a broken watch thinking you're going to fix at the first try which isn't going to happen. But a lot of this depends upon your hand eye coordination skill set and your ability to solve problems and work with small stuff.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
