I read in Hodinkee this morning that ETA won the part of their antitrust suit to stop supplying movements outside the Swatch group. It said nothing about parts. I checked Cousins, and didn't see anything there either. Has anyone seen anything on the parts side of the ETA equation?
That is a different ligation and has nothing to do with parts. Unlike the Cousins one that has been (partly) narrated in details by the British material hose, this one as been conducted in the normal Swiss style, that is nobody except those with a direct interest knows anything about it.
BTW I think is Hodinkee is not more useful than to get swank styling suggestions. To learn more about the Swiss swatch industry sometime Europastar had insight articles.
OK. Wasn't sure. I don't especially care about who they sell movements to in terms of smaller companies making new watches. We need more Sellitas and the like.
Super agree. Came up in a news feed or I wouldn't have seen it (methinks Google has caught onto my interest in watches). The watch universe is divided into two camps: fashion/bling and mechanical object. The Venn diagram has a small (and probably a little blurry) intersection. The reason I spend my time here rather than other forums is because the focus is almost exclusively in the one camp with almost none of the pretenses of the other.
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
