404 Club
A couple of mystery watches on their way. They come with some random LCD modules too. The whole job lot cost a pound.
The LCD above may be a Seiko but has lost its "glass" which is going to be somewhat difficult to source, so I may get creative with this.
The LED is a complete mystery, but the case looks to be in good condition and possibly stainless steel rather than chromed.
Here are the rest of the motley crew.
Edited by AndyHull
6 minutes ago, AndyHull said:
Any idea what the caliber is. I haven't seen one of those before.
I couldn't spot a calliber number, only marking was the *JD on the barrel/train bridge - I included the other pictures I took when stripping down in case you spot anything I missed.
There are still a fair few interesting 404 examples here in the UK. I just picked up this 051/0b Kienzle from the late forties or early fifties for ninety nine pence plus shipping.
I think I may have some suitable gold coloured sub-second hands that will fit it (assuming the pivot is still there to attach one).
I can't tell from the pictures if the hairspring is OK, or the balance is sitting square and complete, but for that price, its certainly worth the gamble.
2 hours ago, Waggy said:
It says Newmark
If you want to know a little more about Newmark (the original, not the new company namesake company set up recently) follow the link.
https://chronopedia.club/Newmark
Managed to pick up this USSR Zim on eBay for only $0.01 a while ago and worked on it this weekend
Here are the before shots:
Balance staff was broken.... and donor #1  had a damaged balance spring...
But Donor number 3 did the trick, finished watch:
I left the patina on the case as it was after a thorough clean in the ultrasonic and then a polish with Flitz as it turned a nice gun metal grey and thought it suited the style of the watch, rather than plating it with shiny nickel.
2 hours ago, SpringMangler said:
Sadly, I remember listening to that match on the radio.
We were in the paddock, in front of the stands, where it started.  We were pushed onto the pitch, by the time we were out the heat was unimaginable.  I have studded fire engineering and the fire was used as an example.
  • Sad 1
On 3/9/2023 at 9:31 PM, Waggy said:
My first 404 watch build, bought a batch of 20 for £57.00 (average of £2.85 each):
Joblot-Of-20-Antique-Vintage-Gents-Watches-Rotary-Etc-Spares-Repair-Steampunk-eBay.png
Here are the before and after pictures. All it needed was a service and new crystal.
And the finished item:
You guys are like rock stars to me. I don't even know where to begin with my petty issues hahah.
I took a look at the "Eros" today. It even got a new old stock strap (new in the 1960s I would guess).
This, despite its size is probably a gents watch and was produced around 1935.
The caliber is likely to be a Phenix 110. although the main bridge shape is slightly different from the one one shown on ranfft.
Clearly a bit of effort was made with the finishing of the movement.
There is a little damage to the plating on the movement and the case, but all in all, it has survived the last eighty pus years quite well.
It runs pretty well all things considered, at around +30s/day or so. The beat error is around 3ms but I left that well alone, as I didn't want to fix it till it was broken.
The mainspring is probably a little tired, but I had nothing suitable to replace it with. I didn't find a suitable small seconds hand for it either, but I will take another look through the stash when I have more time.
Here it is with a couple of other recent additions to the club.
Edited by AndyHull
Working?
4 minutes ago, RichardHarris123 said:
Working?
Absolutely. It is sitting a little fast at around +30 sec per day or so. I haven't attempted to do anything about that yet.
I'll wear it today to let the lubrication settle, and finish regulating it tomorrow, but it seems to run without any issues, at least so far.
Those other two, the Kienzle and the Addora also work, but I haven't wound them today.
Edited by AndyHull
    • What works for me (waiting for the villagers to assemble with torches and pitchforks) is to put a liberal (in watch terms) spot of 9010 on one of the pins of the pin pallet, this seems to improve amplitude and beat error.
    • Non-magnetic is a poor description of such a hairspring. A better description would be unmagnetisable hairspring. There are metals and alloys that are attracted to magnets, but don’t become magnetised themselves. A hairspring made out such a material will be attracted to magnetised tweezers, but will not become magnetised. These hairsprings can be disrupted by being in close proximity to a magnet, but the disruption will cease the moment the magnet is moved away. These are hairsprings that could conceivably be disrupted by a magnetised hairspring stud. Best Regards, Mark
    • More than enough. Here's mine at the height I work at. I think the working distance with the included 0.5x Barlow lens is about 9".   So yes, that halves the magnification. The full story is the objective lens goes from 0.7x to 4.5x. The eyepieces are 10x, giving you the advertised magnification of 7x-45x. However the working distance is unacceptably short, so it comes with an 0.5x Barlow lens, reducing the magnification range to 3.5x-22.5x, but giving you a good working distance. What I did was buy a pair of Extreme Widefield 20x Eyepieces for when I need more magnification. You keep your high working distance, but get your 45x magnification back, at the cost of some width of field.
    • Modern ones after blue steel, invar, elinvar and nivarox , the shiny one are not supposed to become magnetised. But i have had them jump to tweezers. And i dont really understand the comment that what can be magnetised is the stud carrier and rate regulator and they can attract the hairspring ? If the hairspring is non magnetic then how can it be attracted to something else thats become magnetise, its non magnetic , that doesn't really make sense to be ?
    • Does it say 17 jewels on the dial or on the movement ?
