1972 9K Gold Avia
Hi everyone,
This is my first "modern" service - as I said in my hello message, I've always worked on antiques but this watch was presented to my grandad on his retirement in 1972. It then passed to me when my own father died some 15yrs ago. I had it serviced by a professional when I was given it, as at that stage my horology hobby had not started and I wouldn't have known a centre wheel from a chocolate eclair.
It recently stopped running and I mistakenly thought it ought to be straightforward to service....in some respects it was in that the techniques of cleaning & oiling I was familiar with but it was a whole new ballgame - for example, I'd never seen a calendar wheel before and it was more complicated than I expected!
Success though, it's running fine now thankfully (in fact I'm wearing it as I write this!). I was not aware of this fantastic website until yesterday so these photos are not so much a proper service journey but are the ones I always take when working on a new movement so I can remember where everything goes!
You're well on your way with watch repairing having just serviced that one David. The style reminds me of a solid gold Smiths Astral that I worked on earlier in the year. Many thanks for joining in and posting, it's what makes this place special. :)
Thanks!
Yesterday I bought a Ladies Raymond Weil mechanical on eBay for the princely sum of £10....description said "not working" so I've no idea what lies in store when it arrives...but at least spares ought to be available if needed....I'll post the outcome   :)
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile, and not less mobile which is the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
    • Would it be correct to say that the stronger the mainspring, the thicker the oil should be? So for a fusee mainspring, should a thick grease be used?
    • I started on pocket watches as they are easier to work on than wristwatches. Many had gold cases, which is why there are so many movements for sale. I was always on the look out for cases, for as Nickelsilver says,  a 16s movement will fit any 16s case* (with tweaks to the stem). I also started hand winding mainsprings, before I had winders. It can be done without damage, but it's quite hard on the fingers.  But you can make homemade winders, see here      * some movements, eg "railroad grade", have a setting lever on the edge of the  dial at about the 1 -2 o'clock, so need a special case.
    • Ok, on your movement plate you can see a star wheel on the right, this is the silencer, if you rotate the hands by hand through each hour you will see that eventually it acts upon the cam which moves the lever and in turn lifts the lifting lever thus stopping the chimes and strike working.  What you need to do is get your clock to 11pm and also turn the star until the cam lifts the lever and stops the action. The star wheel has a small spring that gives it a positive action between each movement, so once at 11pm you can rotate the star wheel around by hand until it stops the action at 11pm. Hope this makes sense to you.
