my neighbor asked me if i could put a new battery in her lorus nurses fob watch , but unfortunately it still doesn't go with the new battery fitted.
I had a look on Cousins just to see how much a new movement would be but got a bit bogged down by the amount available and ligne size and all that.
As i say its a lorus fob the writing on the movement says Japan and the numbers are PH3N P021J any help as to how to find the replacement most appreciated as my search on Cousins drew a blank
thanks Andy
Sorry Geo of course it would , here you go . :) looking at the numbers with a loupe it is indeed a C and not an O , Rob thanks
Edited by Andyclient
From Esslinger:
Outside Diameter: 6 3/4 x 8 Ligne or 15.3 x 17.8 mm
• Movement 3.15 mm thick
• The height from the bottom of the watch movement to the top of the sweep second pinion is 4.80 mm
• 3 Hands
• Requires watch cell 377
• Requires watch hands: hour 1.20, minute .70, and sweep second .17 mm
• Has NO jewels
• Stem: 354222, Tap 10
• Overall height from the bottom of the movement to the top of the sweep second pinion is 4.82 mm
• Includes watch stem and temporary plastic watch crown
• Hattori Japan quartz movement
• Japanese assembled
US$4.95 and the stem and battery are included!
They list 3 versions: PC21, PC21HCP, and PC21XHCP. The difference is the overall height...so make sure you get the correct one. Corresponding prices increase by one dollar.
Edited by bobm12
The manufacturer lists four versions: PC21AE, PC21AF, PC21J & PC21S
The difference is in the height of the sweep second pinion. Except for J & S, which are the same height. I think the difference between J & S is that J has a longer battery life. (3 years vs 2 years.)
I've got one coming so hopefully it will be the right one , will post an update once it's sorted .
Thanks everyone for your help , most appreciated
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
