Gasket alternative Seiko FH2920B03
Hi, Just wondered if someone had one of these and could measure the cross section so I could possibly find an alternative. I'm pretty sure I can work out the outer diameter myself. It's for a Seiko 7006-8002. Thanks in advance.
Sent from my Moto G (5) Plus using Tapatalk
Can you get vernier calipers? Very cheap and and absolute necessity for watch repair and much more. Anyway, flat gaskets like the one on your Seiko 5 are normally 0.50mm high.
Hi, I have calipers but I don't have the original gasket. I found that part number by searching on Jules Borel website. I currently have an o ring gasket fitted as a stop gap but it sometimes slips out and stops the movement of the winding weight.
16 minutes ago, aac58 said:
FH2920B03 is a square shaped, 0.5 mm width, 29.2 mm ID, black, round gasket.
I believe it's flat with a width of 0.80mm. Below the Seiko document from where such information was gathered.
Edited by jdm
I think it has the old code system, with 4 digits for the size.
8 hours ago, steve1811uk said:
Thanks guys, that document is great. So I think it should be 0.6 high X 0.8 wide? Steve.
I beleive it's a squared 0,5 mm cross section and 29,2 mm internal diameter. It your code were the new style, the shape of the gasket (7th digit, which is B in your case) would be square.
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
