how to prevent a mainspring sliping inside the barrel?
28 minutes ago, watchweasol said:
Hi  It may be the wring spring fitted  could be a dodgy barrel  or the spring could be broken ,   open up the barrel have a look.   Is this watch an automatic or manual wind.?
OK I check that it's a combination of both:(
1 hour ago, Daniel123 said:
Stupid question but have you got it the right way round? I’ve done that loads of times... if it’s wrong way up it will keep slipping.
Ha. I wind it the right way.
I thought this could actually hold that mainspring from slipping inside the barrel. But guess I'm wrong.
Just now, nickelsilver said:
That's what's left of the broken tongue end. You will need a new spring, unless you are equipped to rivet a new piece on (or spot weld).
Yeah It's a learning piece now. I try to weld it but guess I use the wrong material.
Yeah I’d just get a new one there not too expensive on cousins, I should have been more specific when I said wrong way round, if you instal the mainspring upside down the tongue will never engage with the grove on the barrel. :)
    • Hello, I am working on a eta 2970-1 and as soon as I screw down the rotor, the watch stops. The watch runs great without the automatic bridge, when I attach the automatic bridge, it continues to run well, but as soon as I attach the main rotor the watch stops. Can anyone please share schematics or pictures of the automatic bridge? I have looked up a few pictures online and it looks like I have assembled the bridge correctly after cleaning, but the fact that the watch stops as soon as the rotor puts counter pressure on the bridge, points me that there js something wrong with the automatic bridge. Thank you.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This should help you.  704789946_TZIllustratedGlossary(2).pdf
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
