Rolex GMT Master Service Sheet
Rolex is extremely paranoid company. Technical information is extremely hard to get there are a few parts lists out there but it's only for the older stuff. for the most part there's almost 0 technical guides out in the wild as a PDF. this leaves the only source that I know of to get anything that resembles a modern service guide is eBay. Like the manual below really beautiful in color.
https://www.ebay.com/itm/ROLEX-CALIBER-3186-MOVEMENT-TECHNICAL-BULLETIN-SERVICE-INFO-MANUAL-BOOK-ENG/302150612993?hash=item4659947801:g:SbEAAOSwiONYOznJ
56 minutes ago, Peterburke340 said:
Rolex-3135-tech
slandis [ AWCI-DOTT ]
SOrry Peterburke340, this did not come through if you wanted to attach a document.
you can find your parts lists here
https://www.cousinsuk.com/document/search?SearchString=rolex
8 hours ago, Peterburke340 said:
Rolex-3135-tech
I've attached the PDF that's missing from up above. I think this is about the only service guide available the problem is if you look at the table of contents it's supposed to 40 pages long the reality is it's 20 pages. So this means if I place you get a service guide is to physically by one nobody is bothering to scan them into PDFs at least that I'm not aware of anywhere.
Rolex-3135-tech.pdf
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  Can we help with what you are trying to  figure out?
    • In think you are effectively shortening the coil by shorting out damaged tracks. In my case as long as the continuity was good and the resistance not too greatly affected it should be ok .  One was on an era  movement,
