Show off your work space!
spectre6000
Also try looking at the material used for covering drafting tables.  I have a smaller piece of the same material that I use as the work area on my bench. One side is the classic green the other size a cream color and it's about 1.3 mm thick. I'm not entirely sure where mine came from it was left over from when my father used to to cover a drafting table a very very long time ago.  looking on Amazon gives you the link below kind of the starting point.
https://www.amazon.com/drafting-table-cover/s?k=drafting+table+cover
Ohh, and the parts dont bounce much on this? The color green is available on amazon for this.
They surely bounce on hard material, that is also a reason why a bench mat is used. Another trick is to have a large drawer and keep it opened.
Bounciness is directly correlated to hardness. Soft things absorb energy by deflection/bending, so less is dissipated through reflection/bouncing. Drop a cotton ball on a pillow, and it doesn't bounce (soft/soft = mutual absorption). Drop a cotton ball on a steel plate, and it doesn't bounce (soft/hard = cotton ball squishes and absorbs the energy). Drop a steel bearing on a pillow, and it doesn't bounce (hard/soft = the pillow squishes and absorbs the energy). Drop a steel bearing on a steel plate, and it'll bounce nearly to the height from which it was dropped (hard/hard = no squishing, and all that energy has to go somewhere, so it is converted to kinetic energy in the opposite vector in the form of a bounce). Newton's third law of motion.
The converse to this is that softer materials are less durable, and more difficult to work on for other reasons. A flannel backed vinyl work surface would be pretty soft, but wouldn't last very long at all. Also, you'd probably find it difficult to write on. If you're looking at materials, look at the durometer. I've seen SBR sheet rubber used successfully and over a long period of time (same stuff as car tires). I have some newer stock of the same in my shop, and it's good stuff for a lot (once the new tire smell is gone), but it's probably as soft as you'd want to go while still being durable.
Thanks for the informative reply. Sorry i didnt see the notif.
Yes i know the bounciness is related to the surface hardness. But i meant is like does laminated or formica tops reduce somehwhat of the small parts bouncing and flying?
Im making a new bench so thats why i asked
Reduce the bouncing/flying compared to what? If the laminate/formica is softer than whatever you're comparing it to, it should. Neither are especially soft though. If you use a work mat, the composition of the bench top matters much less. Additionally, with softer materials being less durable, replacing a worn mat is much lower impact than replacing a worn bench top.
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
