Illinois 18S Grade 2 Pocket Watch
Hi there to you all I hope you are all keeping safe and well, Can anyone help me with a small problem I have with an Illinois 18S Grade 2 Pocket Watch.Does anyone know how to remove the cannon pinion from the center wheel arbor.It looks like the square that is for hand setting is larger than the dia of the center wheel arbor so I cannot remove the cannon pinion as normal?? Also the center wheel arbor has quite a bit of endshake  so is it possible to tighten this by using my staking set or is there some special way of removing the cannon pinion.Any help would be gratefully received,Many thanks keep safe,Regards,Seth.
the problem with American pocket watches without pictures is too many variations. That's why a picture would be helpful.
or we could find their own pictures so it looks like your standard key wind keys set.  then unhelpful sort of parts book that's because in the early days the center wheel could be ordered separate without the arbor. Or you could buy it with the arbor and you'll note it's missing of the pinion as I'm guessing this is one that can unscrew. But the center wheel looks standard which means the Canon pinion should pull off but it still be nice to have a picture.
Then I don't quite understand the end shake issue which is why picture would be needed.
https://pocketwatchdatabase.com/guide/company/illinois/images?filterSize=18&filterJewels=all&filterMovementSetting=all&filterModels=2
Hi there to all,I have managed to get the cannon pinion off the centre wheel Arbor  with a pin vice and it appears that the cannon pinion was not pushed onto the Arbor far enough as now there seems to be hardly any endshake in the centre wheel.Once again many thanks for all your help and replies,Regards Seth.
1 hour ago, clockboy said:
As I suspected this is not the usual canon pinion set up. This is a key set watch but not sure how to canon achieves its friction.
It is just friction tight. Some of the old fusee P/W's are the same. The cannon pinion can be a sod to remove.
Hi there all,Many thanks for all of your help and replies,As you have said the cannon pinion was a devil to get off but now it's off I can finally strip the movement ready for cleaning whilst I am waiting for a replacement mainspring to arrive.Once again many many thanks for all your help and replies,keep safe,Regards to all,Seth.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
