Hi All
I have just bought a Breitling A13381 Avenger back from the dead. No incantations were used only a lot of work and some new parts. This was very similar to Marks rusty Breitling repair as this one had been plunged into a soapy bath for as long as it takes to have a bath with the crown unscrewed and had suffered horrendous rusting. The owner had pressed the chrono buttons when the mechanism was seized and in turn has snapped the pusher rods. One pusher is completely missing the other has a snapped off screw in the rod. Both springs are present. I need to get two new pushers, can anyone help and tell me where I can purchase them? Here are few pics of the repair. Incidentally the owner told me after I decided to have go at the repair that a high street watch repairer told him it could not be repaired. Well check out the last picture and as you can see she has been repaired.
IMG_6390.HEIC
Edited by Colditz
video too big to post
The vid is OK. If I remember the pusher is spring loaded and screws into the pusher crown , as you can see from the pic it also has two O rings to waterproof it. Getting parts is extremely difficult I found the pusher using eBay.
Hi Guys
I went on Cousins and did a bit of research and it appears that the Pusher listed for the Breitling A11370 Avenger 2 will also fit the A13371, A13380 and the A13381 which is what I have. Can anyone confirm that this is right?
I put a new barrel and spring in. A new reversing wheel (automatic works) a new date wheel (calendar works), new calendar plate screws, New movement case retainers and screws. All other parts cleaned up reasonably well. Thanks to Mark though for video on the rust Breitling it was invaluable. I'm glad I'm a patron.QGPN1528.thumb.JPG.1ea932706a71d744580e9712bc9411bd.JPG
  • 3 months later...
HI Guys
The pushers are still an issue I just cannot find any generic or otherwise. This is so frustrating as the hard work is done. The movement works and I really want to return the watch to the owner. Is there anyone who can help me obtain the pushers and screws for the Breitling A13381 Avenger 2?
I have contacted Breitling direct only to face a brick wall. :(
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
