Bergeon waterproof tester - problem with air leak
rafau
Hi,
I have a problem with my Bergeon 5555 waterproof tester. It loses air pressure when is pumped up to about 2atm. Sometimes quicker than 2atm. The air escapes through the post which is used to hang the watch on. I marked it with the red circle on the photo. There are no other leaks but this one makes the tool almost useless.
Do you know any way of sealing this spot? Any lubricant or... anything? I would say there is a need of gasket replacement, but can I open this lid somehow? :)
Edited by rafau
From the underside, if you take the hook for the watch off (one screw) and the circlip, you can slide the rod out the top. There is, as I recall, a, O ring in the hole. It may be very hard and tricky to get out. In the meantime try some silicone grease and see if that helps.
Much more annoying on these is when they start to leak water around the base under pressure!
I couldn’t find the silicone nearby so I ordered it from a watchmaker’s supplier. Also ordered some replacement gaskets. I will take off the bottom part to get the rod out.
I will let you know if it all worked after the weekend :)
Ok, so this is how it ended:
I actually needed two gaskets to get rid of the leak. Here are the places where they should be installed. One of them was missing...
It was more difficult to place the new ones than getting out the old ones.
Here’s how the old one looked like, well worn:
New gaskets for this Bergeon bought from a famous wholesale shop:
I also put a new gasket on the post:
And as the last step, I put some silicone grease on the post. It moves a lot more difficult now and is more stiff. As a result, it keeps 3atm easily now!
Thanks for your advice!
db75f54f7c4ee263e70a9b289015e64d.jpg&key=3c5529e95348d5ef4f68036892835ea053cb9517d4166f5d41d0656121bc20bb
7e47b553efa3b617d4c3cee69c3388c8.jpg&key=07415a6639252c6a3c9c227bcd33b7a97724bfad4934c2014488ab780730d967
520fa96ee7055ad7e4d875933e1feb2e.jpg&key=7033668f4f3175f24a4c82f8b504f0a88af71b95e5381fedbcaef8475b08b3dc
1fe9b9846115daaf6649fedb81da4df4.jpg&key=0538115728a2fc07f914a45909718385fe4cf168ab7ca3bf0e4027e96fef4302
7ab11ca10b29c2904d14dced018b9b36.jpg&key=ee6009501725685d213e223ab1b1edce7e3d6fdc60720e08e2f1328996b310f0
4fc07c90af7088084bfa56267ca4d6fd.jpg&key=cc6a1ac7129dede87e6960764b6e6fbfacd9b5155f36d18411042af870575a5c
Where did you get the gaskets?
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
    • Thank you very much,T. I'll try turning the arbour from the clock face end very carefully in case I haven't reassembled the suspension block correctly (I had to make up a suspension spring using remnants of a broken one as I haven't been able to find an exact replacement online).
    • Hi murks a picture of the front as well would help,   By the size of the plate it was stuck to I would suggest a coin cell,  2030,  2015 all depends on the height of the cell. And the space when the back is fitted.         3 volt.
    • We seem to have gone a bit quiet on this ?  Do we all agree to ask Mark for some input on this matter, or is no-one really bothered.
