Hi Guys,
                 May i ask where you get your new hairsprings from . I understand that i can buy a donar watch etc but that becomes a little expensive with good quality watches.
  Are there any companies out there that sell new hair springs ?
 Thanks for your help
 Jeff
carpioboy
Depending where you are hailing from, but I buy all those parts from either ofrei or borel! Hope it helps.
Cheers,
Bob
PS. Welcome to the forum!
You can purchase from the company below. However most of the hairsprings supplied are without collets so fitting the hairspring to a collet is a challenge. I have used them but they are very slow to deliver.
Nice one clockboy !
I have a watch repair that's been stopped for ages due to a broken hair spring !  I'll give them a go.  :)
Interesting site.
How do you measure a hairspring to determine its replacement? I don't have the equipment to measure a torque in g/cm/100
...and i don't think the torque wrench I use for my landrover will be sensitive enough  :thumbsu:
Or is it a case of measuring the outside diameter and deciding it looks "quite thin" or "thick"
    • Why do you think this is Fontainemelon ?
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
