Loose collet on cylinder
Hi everyone,
I have a (hopefully not too stupid) question. I have a cylinder escapement from a small carriage clock which someone had used glue on the collet to hold together. I dissolved the glue in acetone and am working on straightening the hairspring as it is bent. However now that the glue has dissolved, the collet will not hold the balance wheel.
I am confused about what I should do next as this is a little above my experience. I know that I need to tighten the collet, but I am unsure of how to do so safely, or even if it should be done before the balance wheel goes in or after. I have seen "collet closing tools" like the Bergeon 3007 but I am not sure if that is only for smaller wristwatch balance wheels.
If anyone has any tips or advice it would be much appreciated!
The Bergeon collet closing tool takes collets up to 2 mm diameter.  But from your photo I have the impression that there is insufficient gap to close the collet. Best solution is to fit a new collet of the corret size. Second best is to glue with Loctite 638 - a professional solution according to Loctite.
install balance wheel and cock in place, tighten cock screw. 1.Turn balance wheel till you see the escape wheel start to move. 2. clock&anticlock with balance wheel, to see this interval within which escape wheel interacts and responds to turning of balance wheel, mid-point of this interval is your TDC (top dead center), immediately passed TDC, impulse is ready to be delivered to the oscillator, which point if marked on balance wheel would fall on a line that goes through balance-escape pivots. Now the escapement is in beat. Mark the limits of the said interval, it's midpoint with respect to a fixed point on manipulate or else as you wish. Next mark on balance wheel, where stud positions when escpemwnt is in beat. Remove the balance wheel, glue collet shoulder, place collet on such that stud is where you marked. please Don,t hesitate to ask anything that may not be clear.
    • Rich, this one seems rather regular movement to me. Yes, what You describe exists, but I doubt that the one on the picture is something similar.
    • @Neverenoughwatches Many thanks for your remarks. As I wrote earlier, I was a bit reluctant to disassemble this movement, and you gave me further motives to be careful. I'll just remove it from its case so as to clean it a little.
    • I am not sure for the terms in english, but if I directly translate from Bulgarian or Russian, there are 'magnetic soft' and 'magnetic hard' magnetic materials. The first group will not get magnetised, thow they will be attracted by magnets. The soft iron for example. The second group, like hardened steel, will get magnetised. So non magnetic hairspring aloys belong to the first group.
    • Looks like it is only dirt. If rust, then this means the strenght of the spring is reduced in places with rust, so the spring is damaged and useless. Only light surface rust, which is rather residual from other places activity of rust can be cleaned, and no chemicals that can etch the metals of the spring aloy should be used Be aware that this usually happens when the dial/hands have radium lume! One of the pivot looks little bent. Not that much to prevent the movement from working, but may be amplitude will be a little bit smaller when this pivot down, resing on the cap stone. Bent pivots always means the balance is out of poise, but it depends on the severity of the bent. Yes it can be straightened, but at this point I will advice to leave it as is and check how the movement performs.
    • Hello, I'm after some help on getting a functional tool for removing and replacing case tubes, the friction fit type not the threaded type. I have previously owned two Chinese Ali Express tools, which worked, but in each case after using on a watch case with an angle the watch had to be manually held perpendicular and when this angle was not perfectly aligned the pusher pin inevitably received a slight side load and the tool body was damaged. Due to the fact that the hole which holds the pusher pin is so close to the end of the block and the material wall is so thin: The result was that the hard pusher pin stretched and deformed the hole and the pusher pin was then slack and no longer perpendicular, and eventually the material split altogether. After I looked at the tool I realised that the block the hole was machined into was aluminum, this coupled with the extremely thin wall made this hole very weak and prone to the deformation and damage I had experienced. I looked to another reputable supplier (see below) who advertised their tool as "all steel" and I even contacted their customer support who confirmed that the block in question was made of steel. I was very disappointed yesterday when it arrived and found that it was in fact aluminum and not steel as promised. I could tell by the feel of the material (weight) and confirmed with a magnet which would not 'stick' and have since requested a return/refund. Assuming the return/refund goes smoothly, I am still left with my original problem of not having a tube pusher tool - does anyone have any recommendation for a tool which will work and will also stand the test of time?
