Vintage Timex Quartz Second Hand Jerky Movement
Was it OK before the new battery was fitted (before it stopped).
If the battery is in the correct way round then it might be the movement is clogged with dust etc. I have not worked on one of these so I don,t know if it is a serviceable unit. It might be possible to change the whole unit at a very reasonable cost.
The movement looks like it needs a good clean and service. There is a good chance something has seized and the the motor is incapable of driving the the gear train.
I'm sure others will pitch in to help.
Take a look at some of Mark's videos for quartz watches on www.watchrepairchannel.com
Notice how careful and patiently he performs each step. That's how we're to
work on watches.
Don't be afraid to undertake this. It's how you learn; and remember to use the right tool for the work to be done, shortcuts will only lead to ruined parts, and set-backs.
After you perform one task, take a break and think about what you did and how you did it. Take pics of each phase, it'll help when you need to know what part goes where because you will forget.
Take your time and be patient, it doesn't have to be completed in one sitting.
Edited by mlfloyd1
Hi eyebidder,
In my mind that shouldn't be a very expensive watch, please correct me if I'm wrong, so it would be good to experiment on. Remember that being Timex the movement in question may be hard to find if this one is damaged. I have a suggestion but this will include removing the dial, hands and battery and in fact anything that is not the movement itself. Then spray it with the following:
then blow dry and replace removed parts. If the problem persist, try to force spin it in the appropriate machine...something like this:
This is just a thought and I have never tried it (but I will eventually). So, your call and own risk...might be worth a shot though.
Hope this helps,
Cheers,
Bob
PS, Welcome to the forum!
Geo, on 25 Jan 2015 - 04:59 AM, said:
What about this Bob, do you think it would work?
That is a pure Aussie invention with an appropriate name ... all our very best inventions have "**BLEEP**" in their product name :p
That stuff is good for everything: from a lawn mower that won't start up, to a hang-over cure, and breath freshener for the morning after :wub:
... Honestly!  I wouldn't lie about such things! :rolleyes:
    • Just missed it! I have a donor movement on its way. But thank you for the offer--I'll let you know if I need anything else.
    • My latest. Timex 2465. Replaced the crystal, caseback gasket and spring bars. All in less than $5US. Added a gray NATO strap I already had in stock.
    • I have some Gruen 510's in my donor pile if you need parts.
    • I've been intrigued by everyone's input here...so I decided to give this a shot. I bought the"typical" Pearl watch-machine basket and trays, for about $65. The trays are good,..the housing is a nightmare ! Thought it would take the mixer off my bench at anything above about 200rpm. The housing is cast of course,..and it's not "true" at all...so the harmonic vibration was insane. So,..I bit the bullet and bought the Elma housing and top. Not the baskets though, as the Pearl one's fit the Elma. Saved a bunch there. The basket and lid came to about $80 with shipping. The opening in the Elma top is 8mm, and the shaft that came with my stirrer is 6mm. I bought a piece of steel tube, 8mm O.D., and 6mm I.D. Cut off about an inch of the tube, and drove the rod into it. Gives a really snug fit.... Lightly champfered the leading edge of the 8mm section, then lightly tapped it into the top of the Elma lid. Spins like a dream now So... I have about $240 total into this including jars and steel mesh for the wave breakers   I'm pretty happy Best to you all   Randy
    • Still haven't gotten around to getting stems or screws, but I did make my first attempt at polishing a case. I just used a soft mop and rouge to reduce my odds of ruining them, and I think they came up pretty nice. Also gave the crystals a polish on the same wheel while I was at it. They were both very badly scratched up. The one on the left is fairly beat up, but it'll still make for a decent presentation.
