Hi friends, a quick question about chrono pushers. I’m replacing them on a 6138-0020 and noticed that the one I took out is shorter then the replacement. It's a little sticky too, although I attribute that to the new gasket?  The longer ones work, just seem to stick out a bit. Would anyone know if seiko made different pushers for different models of the same caliber (-0040, -0030, 0020, etc)?
I don't think they made different but is easy to check, on Cousins UK enter the case ref. to verify.
If you’re asking if they’re different pushers for say the UFO vs the Kakume vs the Panda....then yes, I’m almost certain there are. I own a UFO, and that has concentric circles in their pushers (something to look for when determining authenticity) but I don’t believe all other models have this. I only know for sure with the UFO cause that’s what I did the most research on.
I would look at it like the pushers are more a part of the case, then the movement. Each case type is gonna be different.
If you’re asking does the same case type have different types of pushers? Then I can’t say for sure...but knowing Seiko....possibly. Wouldn’t put it past them.
    • Heh. Well, also I just want to be able to do it, for no other reason than it's interesting. Same reason I restore antique tube radios and ancient computers- like, from the 1970s.  Sometimes, the parts just aren't there and you have to know how to make them. Learning how is a challenge and can take months or years, but it's honestly the best part! You can't beat that sense of triumph when you do something that's really hard to learn to do and do it well.
