Hi guys,
ive scuffed my bracelet, no idea how but I’d like to try and salvage it if possible. Can anyone help advise what the process is? On the polished bits I’ve always used cape cod to good effect, not sure how to work on these brushed parts though.
10 minutes ago, jdm said:
20 seconds of scotch brite, passed in one direction only.
You mean no fancy tools needed? :biggrin:
Is this what you mean?
Edited by AP1875
I got the Scotch-Brite and it worked really well :-)
I have a few links with scratches and dents, the scratches will come out with cape cod but when it’s a little deeper like this what is used?
Buff it first with rotary tool, a 5cm hard felt wheel and Dialux Orange works great. If you want it shine then polish with Dialux Blue, otherwise if it's a brushed purchase go directly to the green pad. There are also different grain pads for a finer finish.
 Thanks for the info JDM. As you can probably tell this is a side of the watchmaking/restoring hobby i'm just starting to venture into. It does really interest me though. I'm going to buy some cheap bracelets from cousins scratch them up and see if i can get them looking 'new' again before i cause this bracelet anymore damage.
So, for the 5cm felt wheel would this be ok
https://www.cousinsuk.com/product/050-to-0150mm-felt-wheels-made-in-uk
Dialux orange and blue
https://www.cousinsuk.com/product/dialux-rouges
Any suggestions on a rotary tool?
Thank you
Much better is to buy beaten up SS watches on Ebay. Restoring is not difficult, and very rewarding.
Quote
Even cheap Chinese are OK. What you want is good mandrels for the wheels, also great is a support for the tool.
Edited by jdm
Not really sure where to begin with selecting this type of tool but I guess my first question should be is this the type of tool required?
https://www.cousinsuk.com/product/cousins-polishing-motor
That is a motor as I have, beside that you can get it for much less on AliX, rotary tool means something  hand held like a Dremel, Proxxon to mention brand names, but even a Chinese no name is OK, or a drill on an improvised support. Results mostly depend by case in question and technique, if you only have to restore you few pieces it's pointless to spend much. Get also smaller wheels as it's easier to do precise work and avoid edges.
Edited by jdm
3 minutes ago, AP1875 said:
I do actually have a Dremel. It’s a rechargeable one.
https://www.dremeleurope.com/gb/en/dremel®micro-898-ocs-p/
I guess I need a bracket to mount it to a desk and something to hold the hard felt wheel.
Hopefully Dremel make both of these attachments.
Small repairs like the above can easily be done hand held. It's when working of deep dings or large areas (bracelet clasp are surprisingly time consuming) that a motor or a bracket really becomes really a saver. Don't forget to wear cotton gloves and work inside a cardboard box because is a bit of messy work.
Thanks a lot, I’ll save my money for the time being and hold off on the stand. Hopefully I’ll update here in a few days with a nicely polished part :thumbsu:
    • I expect the stem on the Citizen will have snapped but if you're luck they'll be enough protruding from the crown to unscrew it. Do you know what movement's in the Citizen and what all the movements look like for general condition.
    • There are specific dies that will mostly fit this crystal shape, but I just find it easier doing them by hand. Occasionally the odd one can be difficult, there is a workaround, and it isn't by force .
    • To anyone who might be able to help. I am coming up on almost 20 years since I bought an Emporio Armani Meccanico AR 4205 watch. Sadly the crown and main stem is now missing due to an unforeseen accident. I went to my local store, they sent it in for repairs, but returned it due to being a model that has gone out of date. The watch itself is not very expensive, but it holds a great sentimental value to me. So I figure it would be a nice small project to get it fixed on my own. But since this is my first dive into wristwatch repairs, could anyone point me to somewhere on the web where such parts could be bought? Or if there are parts from a different model that would work on this? Any and all assistance in this matter is greatly appreciated :)
    • How does the size of the new compare to the old.
    • As I wait for my first set of watchmaker screwdrivers to arrive, which is taking longer than I had hoped, I'll post a photo of the small stockpile I made to work on. I'll be starting with the Citizen: the missing crown is my doing. I unintentionally applied pressure from the side and off it came. I've put it aside, and I'm hoping it's detached rather than snapped, and without damage to other parts, but until I have the screwdrivers I can't remove anything to examine the stem section. Two of the Seikos are are working, quite well actually, although for the price I paid, none of them should really be in "serviced" condition, so after letting them run on one wind, I've left them unwound.  The Citizen was the cheapest, and so the one I could most bear to go wrong with, although all of them are rather nice watches. I think they're all from the late 50s to very early 60s, but I haven't managed to date them more closely than that. The Citizen and the Seiko Crown each have a small crack in the crystal, so I'll be hoping to replace those.
