The name on the watch is probably just a retailers name, there was a jeweler registered around 1900 in New York of that name, pictures of the back of the watch would help, some watch cases are screw on.
I got the case open!   It was pretty gunked up and just needed extra coaxing.
Anyway, the movement is engraved with the same Julius Ewoldt New York20200303_101734.thumb.jpg.0cc5ca1f7cea03eaf324aeb07646edbe.jpg. There is a movement serial number of 1666774 and, on the regulator cap is a swiss cross and the numbers 1683. That's it for markings.  I agree that the jeweler of the same named makes perfect sense.   We have long ties to 1800s NYC.
Hi,
The movement is a Longines Cal 19.75 the patent refers to the regulator and was filed in February 1899, so the watch you have is a private label Longines signed both on the movement and dial by the retailer, the serial number of the Longines movement dates it to between 1904 and 1905.
16 hours ago, wls1971 said:
Hi,
Not to knock your knowledge, but it looks as if the cal. 19.75 movement has a single bridge plate for the train, whereas the cal. 19.71 has the 3 separate bridges for each gear in the train. If I'm wrong, I'll retract this post.
e8624600021e6e4fe896e45ab8a07b22c378cafc.thumb.jpg.6023a164a1b8eddd5fc6b4f265480e19.jpg
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
