Timex Q movement swap
philipk65
Hi Everyone,  I have a 1980 Timex Q quartz watch that was a graduation gift and hasn't worked in 20 years (battery corroded).
I bought a working one off of EBay and want to swap to movement. I've seen online all it takes is pulling the crown/stem out and the movement, face and all
comes right out. Not this timex. I looks like there is a ridge round the case and some sort of metal fingers at need to be bend to remove movement?
Any advice would be greatly appreciated!  Thanks!   Kevin
The 'metal fingers' hold the dial onto the movement..........
This watch, like most of, if not all, of Timex's early quartz watches , is a 'front loader', in that the movement comes out of the front of the case, after removing the crystal. On some the front bezel has to be prized off to remove the crystal, on others the acrylic crystal has to be removed with a crystal puller, like this:-
With these ones it is obvious as the crystal has a high dome and pronounced vertical section that protrudes above the watch case, that the jaws of the puller engage on....
Hi  Thats better although the one of the movement is a bit out of focus.  Judging by the dial there has been water/moisture ingress.    Is there a model number on the back.    It does look as though the movement is removed through the front.  As JohnD mentioned  you will need a crystal lifter to remove the crystal and then the movement.  I am not familiar with these at all, but to remove the stem look for a release lever, pull the stem out and observe how it is locked in place. Some require you to lift the release lever and others require a pair of tweezers to open the locking spring. I recall that it was shown in an earlier post so have alook via the search in the top right under timex.
  • 4 years later...
The pictures are showing the M42 movement in your grandfathers original watch.  I actually have one and it's a unique movement since it only advances once per minute so if you had it open and put a new battery in it you need to wait a minute before you hear the sound of the advance of the minute hand.  Timex only made them for two years. Notice it doesn't have a second hand because it's not needed.  You can find more information here on the movement https://17jewels.info/movements/t/timex/timex-m43/  I have attached a couple of pictures of my 1990 Quartz with the M42 movement.
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
