I have been servicing a Bulova ladies watch, movement 6p. This is a mid to late 20's vintage watch. Watch has been cleaned, and oiled. Train is free, end shakes ok. Balance and hairspring are fine. I removed the barrel and cap, pushed down some coils along the outer edge of the barrel, and applied 9501 grease along the top of the coils. The watch rain great after that but after an hour or so stopped. I noticed I had left the crown and ratchet wheel screws to try and troubleshoot. I tightened those and it was running like a champ again. After coming back from an outing, it had stopped again. Balance moves very well while putting lateral pressure on one of the spokes on the center wheel, indicating power is not being transferred. I have checked to make sure the barrel cap is snapped down flush to the barrel. Arbor pivots are oiled. Does someone know of a common location to check for next?
Hi Charlie,
Although I am fairly new to this, not familiar with most Bulovas and never serviced a small movement of the kind women watches use, I would venture: how about the jewels? any of them cracked or chipped? Main spring slipping inside the barrel or unhooked from barrel axel/pivot?
Hope this helps,
Cheers,
Bob
Is it a auto.  Had a similar problem with a ladies watch fitted with a Eta.  Changed the reversing wheels and put braking grease on barrel rim and the problem went.
Edited by clockboy
Thanks for your input Bob. I always inspect the jewels during disassembly.
Clockboy, this is a 1920's piece. Hand wound with only two hands.
Well, I think I may have found the problem. There is obvious scoring on the bottom of the barrel bridge all the way down to the brass. I put a few very very tiny spots of blue grease right where the scoring is. I put the ratchet wheel back on and the grease was gone. So it seems like the ratchet wheel is contacting the bottom of the barrel bridge. The arbor is not protruding enough through the bridge to keep the ratchet wheel well elevated above it . The ratchet wheel thickness should be reduced here rather than file the barrel bridge, but I don't have my lathe set up. I might try a small dial washer over the arbor first.
Thank you both for your input.
Charlie
Hi Jerry, what do you think has changed to cause this situation? It doesn't seen right to thin down the ratchet wheel. Could there be a small washer/spacer missing?
Have you checked the barrel arbor pivot holes in both the main plate and the barrel bridge for wear? Excessive wear in either of these places can cause the arbor to tilt such that the ratchet wheel can contact the barrel bridge on one side. If this is the case then the correct repair would be to re-bush the worn pivot hole, although on something as small as this that may be quite a challenge.
I think that may be what is happening, although the arbor barely protrudes the plate as well. The score marks are brass and are on only on one side of the barrel bridge recess on the bottom, which may point to the barrel being tiled.
Marc,
I have checked the arbor pivot hole in the bridge but not the plate. The bridge hole is in excellent shape, I will be checking the arbor hole in the plate this evening. If it is quite worn, I would be tempted to install a jewel instead of a bushing, provided there is enough material to hold it firmly . There is a caveat though, this would be my first attempt and this is a friends watch.
Edited by Charlie
If you've got the equipment for installing friction jewels, and as you say provided there is enough room in the plate to accommodate it then that would certainly be a solution.
If you are unsure about the process Mark has recently done one of his excellent videos (vintage Omega 30T2) in which he replaces a badly worn centre wheel bearing with a jewel.
Also if you have an old main plate from a scrap watch or even a scrap piece of brass plate you could have a practice run on that before tackling the Bulova.
Assuming you have a jewel the right size the most critical thing is ensuring the axis of the hole doesn't shift from where it's supposed to be in the process. As far as end shake is concerned so long as the jewel is pressed flush with the train side of the main plate you should be OK, but this can be adjusted fairly easily.
Good luck, let us know how you get on.
Edited by Marc
Thank-you Marc,
I have seen Marks videos on installing jewels. It does give the amateur much confidence to say the least. Excellent tutorial and it takes the mystery away from how to take the measurements and proper sizing. I own a complete Seitz jewelling set. I would perhaps order two jewels, one for practice and one for installation on the Bulova.
I wound the watch fully last night and it was running fantastic for a good half hour, with amplitude over 300. In the space of several hours, this amplitude deteriorated. When I awoke the next morning, it had come to a complete stop. It is temping to provide further clearance to the bottom of the barrel bridge to clear the ratchet wheel and look for any improvement. I may have to resort to this measure if the main plate arbor hole is found to be in good order like the barrel bridge arbor hole.
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
