Franklin mint watch help
Darrel22
found this watch in a house clearance -  on the watch case is says the Franklin mint c 1989,  I think some of the watch could be gold but not sure ,  As you can see it looks in very bad shape and I am not sure if it is repairable  .  from what I can see there is Rust on some parts from possible water getting in - the front glass is missing from the watch  -     At the moment I have been learning on a cheap  ETA 6498  watch  so I have limited experience in watch repair,  so I might keep this watch  until I have  gain more knowledge of watch repairs .  As for the back case I think its a pop off  type but it feels stuck on and so far I cant get the case off,  so any advise on this watch and what I should do with it  will be very appreciated , if its just scrap I might just use it to learn on now  or for parts .
From the little I know about Franklin mint is from the 'collectors coins' they sell.
Usually for very high prices, but they have very little resell value, the same is probably the case for their watches, but either way with the amount of rust showing for what it would be worth I'm not sure it would be worth fixing.
Although a quick search did turn up that Franklin mint did make some gold cased watches so it is probably worth a look at the case atleast to see if its solid gold or just plated.
If solid it should have a hallmark somewhere.
From the position of the balance etc., It looks like a variant of the skeletonized "Chinese Standard movement", and as such is not really worth much.
There are several different versions of these movements, but they tend to have a similar layout, but different bridge configurations.
Does the movement have any numbers stamped anywhere on it perhaps under the balance, or on the bridges that might help to identify it?
Does it claim anywhere on the watch that it is Swiss Made?
Franklin Mint -> https://en.wikipedia.org/wiki/The_Franklin_Mint
In my limited experience of their stuff,  I would tactfully describe as perhaps slightly higher quality than Gerald Ratner might have been selling... maybe. Check for hallmarks, if there are none, then treat it as a good piece to improve your watch cleaning skills on, but little more.
Edited by AndyHull
Not all Franklin mint stuff was tat, they have sold some very nice clocks, by makers such as Imhof, Lepee, and Thwaites and Reed  Their Royal Geographic world time clock and inclined plane clock where very good quality and fetch good prices.
Thats interesting to know.
I really only know them from the adverts they used to put on the back of the TV guides selling overpriced pewter items.
I think if you unscrew the screw a few turns to the right of the winding stem in the photo that would release the stem, but looking at your previous photos the other side looks looks pretty rusted so it might be seized.
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
