Identification.
fjseal
Is it normal for a clock movement to have no visible form of identification, if so, could it be hidden out of sight somewhere. How can one make a start on finding, for example, a new mainspring or the age of the movement . This is the clock I asked  about earlier regarding mainspring condition. Watchweasol thought it could be of European, possibly German origin.
Definitely one to call in the clock big gun contributors to ...
...however whilst eating my lunchtime sandwich I thought I'd spend a few minutes looking around and came across this which certainly looks like your case and indicates a thermometer would have once been present: https://www.antiquesnavigator.com/d-1201283/antique-victorian-deskmantel-clock-barometer-thermometer-good-working-order.html. Of course, like yours, no clue on a maker but then I thought I'd take the barometer face design as an angle because that lettering and spacing is pretty distinctive and came across: https://www.tooveys.com/lots/266080/a-late-victorian-aneroid-barometer-with-carved-oak-circular-surround/ . Your pic is a bit fuzzy but the similarity is obviously there with this one ... and interestingly it has "Guaranteed English Make" on it. Now of course whoever put your mantel barometer-clock together originally might have mixed English barometer with European/German clock but if in the unlikely event our forum's big guns are stumped then a search along the lines of victorian english mantel clock movement might be worth a go.
That is German and it’s an 8 day duration. The balance staffs on these clocks normally wear and the tips become like a blunt pencil, so they need to be pointed, so you need a lathe to do this and re-point using a stone, I used a small arcanses stone to do this with oil. Also check the cups as these can also wear, if so they need to be smoothed out by means of a countersink.
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
