How do I put this in beat?
Lc130
I'm a beginner and this is a replacement balance for an FHF 28.  In the below pic the jewel is centered in the banking pins.  The stud is circled.  The stud arm is fixed.  The balance cock is roughly aligned in its proper position.  Is there any more to this than trial and error?  As a beginner, I've learned it's best to handle the balance as little as possible.
Thank you
Charlie
Edited by Lc130
If so " impulse jewel is centered in mid banking"  then HS or Roller needs to do a 180 degree.
Check if balance is a right one. Just put cock back on ( no need to get the stud and HS back in their place) . Once balance is installed you can tell if staff fits and wheel turns good. If it dosen't you got the wrong balance.
If balance is the right one, 180 is in the order.
Mark has a great video on this procedure. It’s easier to do if Hairspring was not attached but in this case if the balance came complete and is correct i would think the stud should be in the correct position, so you will have to make sure the roller jewel sits between the banking pins as perfectly in the middle as possible. You can adjust the position with the stud on top of the balance if needed.
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
