Hi all.
I am doing a refurb of my sons Seiko and it has a few issues that need replacement parts. This is a bit of a long shot, but I am trying to source a replacement crystal for it as his is quite badly scratched. It would be nice to have an original Seiko part, which I think is a low-domed Hardlex, but I but I don’t know where I might source one. Or is the only option now (it’s a 2006 watch) a generic replacement?
Also the clasp is broken and as it’s an integrated bracelet, I am having trouble finding spares for it. Again, anyone have any hints as to where spares might be found?
the watch itself is fine, just needs a new battery and reseal, but a quick trawl around eBay is not giving much in the way of results on spares. Anyone know of a source of spare part information for these older Seikos?
Mine is the black dialed version, but in all other respects is the same watch.
Happy New Year to all here.
Edited by Moose
Added info.
Expand
Even if badly scratched an hardlex crystal can be polished perfectly, there are many topics on the subject. Crystal P/N is 330PA2HN02. There is no magic place to source parts, all you can do is search on the Internet.
Edited by jdm
Expand
Hi, and thanks for the reply. I know there in no magic Santa sack of bits, but I also know, that other people sometimes know more than I do about where some of them may yet be found. I will certainly have a look at how to refinish a Hardex as a first base, thanks for the tip.
  On 12/26/2019 at 7:32 PM, watchweasol said:
Hi   you could try the SCWF site which is exclusively seiko citizen watches. I have attached three tech docs apertaining to the 7T92 which may be some use to you.
7630_Seiko 7T62A, 7T92A, 7T94A Part 1 of 3.pdf 796.35 kB · 1 download 7631_Seiko 7T62A, 7T92A, 7T94A Part 2 of 3.pdf 666.53 kB · 1 download 7632_Seiko 7T62A, 7T92A, 7T94A Part 3 of 3.pdf 825.18 kB · 1 download
Expand
Excellent, and thank you for the docs. Once the Xmas “cheer” has worn off a bit, I may even be tempted to have a go at a clean and re-lube. Done a few manuals but not tried a quartz yet as I have never had one that was worth the time and effort.
Best wishes for 2020.
George.
I have seen domed sapphire crystals on alixepress. Truth is, polishing takes time and a bit of equipment, which can be avoided in many cases.
Expand
I agree. Having now looked at the process for Hardlex, it seems a lot of work and not by any means, always good results. I think I’ll just take out the old one and measure it to see what replacements I can find.
cheers and thanks for the replies.
George
Edited by Moose
It's a 33.0mm crystal, which is a common size. If there isn't anything special is easy to get a generic replacement for cheap.
    • The problem/challenge with these things is that you don't know what brilliant solutions previous watch-tinkerers have come up with. Are all parts even "original"? Did the watch run ok (-ish) when you got it? One possibility is that a replacement staff has been fitted and turned out to be a loose fit.  Some of this has been discussed in the following thread:
    • @GuyMontag good find! Even the micro stellas are cloned in the Daytona fake! Around $2600 is mentioned in the thread. https://www.reddit.com/media?url=https%3A%2F%2Fpreview.redd.it%2Fnewest-development-from-ace-v0-61r4zxq1q2xd1.jpeg%3Fwidth%3D1080%26format%3Dpjpg%26auto%3Dwebp%26s%3Dd5dd3a29a3d1668077d4a4c894a09c76f6f66de9
    • See I wondered about this because Frei only lists one part for 18 size, no left or right options whereas they specify left and right for the other sizes. (I happen to be working on a grade 88) I recall seeing an old video of Elgin making laps and jewels in the factory (maybe you were the one who shared it) I have one very weird warming tool which has springy jaws that can open wide enough to hold this type of fork flat, and it swivels so you can position either side over the heat source. It works great for melting shellac on a firmly held fork EXCEPT can you guess what its fatal design flaw is?....   ....you cannot open the springy clamp once it has been heated because you would need to pinch them both between your fingers and you get a second degree burn. Genius.
    • The other thing that makes pallet forks like this interesting is or some of these interesting it when they're not level they don't fit well on the pallet fork warming tool and melting to shellac becomes a challenge. One of things you want to do when working on vintage pocket watches is accumulate broken pocket watches and swiped the jewels from them. Because as you're finding out the vintage jewels were probably not made out of Sapphire there are made out a Garnet and Garnet doesn't seem to hold up as well as shellac. Then the last little part about stones pointing in different directions doesn't make sense? There's always a left stone a right stone angles are different and they both have to be in the same direction. Although I once had a pocket watch command were somebody put one of the stones in backwards and surprisingly the watch ran. Then on some watches I done this with 12 size watches I've been able to swipe pallet stones from other 12 size not even the same company because they may have purchased or stones although Elgin I know at some point in time did make their own tools and had a separate section of the factory that made diamond grinding compound for all their lap and during work. Then when the company got liquidated the diamond division was sold the somebody else in the last I knew it was still running out there but not of course under the Elgin name. Still making diamond grinding compound.   From the 1915 parts catalog you can see all 18 and 16 size pallet stones are basically identical. The difference is what they're made out of and one of them that they didn't policy side in stone probably in a seven jewel watch no one would ever see that anyway. Then you have a new or the old style determines its thickness and you would have of course right and left Then I'm attaching a PDF of Elgin escapement terminology is it is nice drawing to show you the difference between the left and right stones. Elgin watch company Escapement Terminology.PDF
    • The roller table is supposed to be held on by friction. If there is shellac under the roller table it might indicate that an improper repair had occurred prior to this as it would not be held in place with shellac. Sometimes overenthusiastic people re-shellacking the roller jewel will get shellac where it's not supposed to be. Then the picture of your roller it looks kind of damage? It doesn't quite look right it looks like somebody held with a pair of pliers or something? Then your balance wheel has limited quantity of screws? Not necessarily a problem but an indication of perhaps with the other things a prior bad repair perhaps as a guess.
