Hi, I was given this watch recently, I really like the design and want to look after it, I dont know anything about it apart from its a Swiss Emperor Hi Beat and the watch pops out of the case, it seems to keep good time, Id like to get it fully serviced and restored to the best it can be, so  im asking if anyone knows much about this watch, if its worth restoring and perhaps point me in the direction who could do this.
Thanks for reading and happy christmas
No picture of the mov't? It's a front loader, there are many topics on the subject.
Just be aware that servicing done by a reputable repairer can easily exceed the value of the watch, although I recently found that the well know collector DR. Ranftt recommends someone with very reasonable prices.
I braved up and popped the back off the watch, I know nothing about this subject tho i do love engineering ..... any way i noticed someone had added some sort of spacers to the movement, the watch does keep good time so i presume the movement is good, im just wondering if this is worth any time and effort, i really love the style of it
I think it
"Good time" is a positive practical start but just an "owner statement" from a watchmaking point of view :), as there is much more to assess a watch is "healthy".
I think it's a pin lever? It has some quality i being 17 jewels with shock protection  the design is cool and wearable. Try some rally leather straps on it. Then if you join the main objective of this watch repair forum you can become able to service it yourself, a good way is by enrolling our Host's HD training: watchrepairlessons.com
And season greetings!
Hi  have a look at the movement and look for a calibre number and makers mark so as we can indentify the movement for you. It should have a symbol i.e  eta 2428 or somthing like which identifies the movement.  From first observations it looks like a 17 jewel lever movement and worth renovation. But as jdm says renovation can easily exceed the value of the watch.
Using a x10 lens i think it says .... 17 jewels unadjusted swiss made 21¬500 a/ h  ........E.Gunzinger Co 7
Id like to see this watch serviced and now ive had the back off perhaps a better spacer put in, i shall phone a few local watch repairers, see how that goes, im not into watches or wearing them, the watch is from the 70s all original including strap, i just think ill give it chance before i throw it in one of my junk draws to slowly disintegrate ..... thanks and happy new year
  • Confused 1
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
