Hello All,
I bought this watch for my brother for Christmas. I decided to disassemble, clean, reassemble and oil. After completing the job, I tested the motion works (failed to test prior to disassembly) and it seized: It simply will not turn. I have narrowed it down to the wheel identified in the attached pictures. (note the keyless works seems to be working fine) This wheel has a wheel at both the top and bottom (dial side) plates and it has a pinion that engages with the going barrel. The bottom plate wheel-see photo-engages with the intermediate wheels of the motion works. Everything works fine, of course, until I install the pallets, then nothing moves. When I pull out the crown stem, with palletts removed, the entire wheel train, including second hands pinion and extension move. For some reason the wheel train and the motion works are not acting independently. I purchased another Volna Cal 2809 movement on ebay to see what I may have missed but thought I would ask you folks if you have any ideas.
Thanks a bunch-this is the first time I have been stuck in a year or so...Mark has trained me well.
Bird
I'm not familiar with this movement but you could have an offset cannon pinion and that may be frozen in place.
Try to grip the pinion with and work the wheel to loosen.. don't use too much force as the wheel is delicate.
Good luck.
Anilv
If it is something  like the 2209 there is a pretty  large  gear at the bottom  of that wheel that engages another gear.it is pretty  picky about placement. It is possible  to install  it incorrectly   so that  it does not mesh. Re install  carefully  under magnification. That  wheel  and the second hand shaft  ride in jewels  in the barrel  bridge. On the 2209 I have had the best success  by installing  the train bridge  first. Then installing  the barrel  bridge without  the mainspring  to check that nothing  binds. When I am happy  with  the mesh I then install  the mainspring..
Edited by yankeedog
PS what you have is the only ever chronometer  grade mainspring  watch ever produced  in Russia..it is a fine piece  of engineering  and it is worthy  of your efforts.
Oh.. missed that this was a 2809.. the so called Zenith copy. And yes, that's an offset cannon pinion.
I have worked on several and while the movement is nice I had a lot of problems with the hands as the hand no tube, just holes which were worn.
That would make a nice present.
Anilv
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
