Eta 2824-2
Jim
Hi everyone hope the holidays were joyful for all.
I am currently servicing an ETA 2824-2   and have hit a roadblock.  I need to put the watch in beat and the hairspring collet used is something I have not seen before.  Rather than a standard round collet or the V type this movement has a collet that resembles a four leaf clover and no slot.  I assume there is some special tool that can be used to adjust this but I have not been able to locate it.  My only other thought was to take an old stake and grind down the sides to make a tool.
Any advise would be most appreciated
Sincerely,
Jim
Found this on the net hope it helps
You can regulate a ETA 2824-2 by turning the eccentric screw (red arrow). For co**BLEEP**r regulation, you can shift the green arrow, but if you shift it noticeably, the rate changes significantly (so move it with caution). Do not touch the blue part as it changes the beat error, and you won't be able to correct it unless you have a Timegrapher.
Thank you for the advise.
I am using a timegrapher   the beat error is over 6   ms   and moving the blue arrow only gets me down to 4  the amplitude is also horrible    What I need to do is move the hairspring to get the watch at least close to in beat then I can fine tune with the blue arrow above.   But the collet holding the hairspring is not standard  so it appears a special tool is needed.   Just was hoping someone has put one of these in beat before   :-)
Sincerely
Jim
I presume at some stage the hairspring has been removed from the balance for a large out of beat error. If has not it might be worth checking that it is actually a beat error. Mark has a vid showing how to check this see below: If the hairspring has got to be moved someone for sure on this forum will have the answer.
Jaycey   Hey thanks for the post  I wish I knew if that was what I am looking for do you know if that fits 2824-2?
Thanks for the post  at least i am going in the correct direction.
Sincerely,
Jim
I presume at some stage the hairspring has been removed from the balance for a large out of beat error. If has not it might be worth checking that it is a beat error.Low amplitude can also be caused by damaged jewels or damaged balance staff. Mark has a vid showing how to check this see below: If the hairspring has got to be moved someone for sure on this forum will have the answer.
Sincerely,
Jim
Ahh I see, no that tool I linked to is not for that.
I am fairly convinced it is beat error typically ETA movements run low amplitude less than 200 new even the clone movements are higher, This one is in the 150 range  but I believe the amplitude is off because the beater error is so extreme.  I have played with this movement for a while now  lol  I feel confident if I can get it close everything will come into place.  I just need help with that collet.  Notice the nice slot in Marks video   BTW the watch was cleaned and serviced pivot ends are good jewels are fine.   Hope Mark chimes in  :D
Sincerely,
Jim
I have searched the net and could not find any specific tool for this style of stud. A stiff pair of brass tweezers might give enough purchase to move it but this can be risky so if it was me I would use the safest way possible and mark where it is positioned then remove the hairspring using the normal methods & re-fit to see if it improves or not.
Out of curiosity, in the diagram above, what does the arm that adjusts the beat error (marked with the blue arrow) actually act upon to make adjustments?
It's the anchor point for the end of the hairspring.
jaycey    The Blue arrow points to the stud end of the hairspring  as you move it one way or the other it changes the center point of where the balance roller jewel is striking.  This is the beat error adjustment as noted above.
Sincerely,
Jim
What Geo posted was very helpful.   I bought an etachron tool  and ended up adjusting the regulator pins.  I found if they are not aligned correctly it also causes the watch to read out of beat.  Once I had those adjusted properly i was able to use the beat adjustment and affect a change.  I never did need to move the hairspring collet.
Thanks again everyone
Sincerely,
Jim
Sincerely,
Jim
That makes sense. Well done :)
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
