Reversed regulator
Buffo
G'Day,
I'm in the process of getting a mate's old Turkish pocket watch movement up and running again. I'm at the point where the movement is running well and keeping reasonable time, but I notice that the regulator seems to work in reverse. In other words, when you move the pointer towards "F" or "A" the balance wheel slows and when you move it to "S" or "R" it speeds up. Any explanation for this?
Thanks,
Rob
FNQ, Au
213042986_Turkbalance.thumb.jpg.b08e6f1c0b1abda5e9308beab560de97.jpgG'Day nickelsilver,
Thanks for replying to my question.
Both index regulator pins are present and the gap is small and pretty much spot on. When running, you can see the spring oscillating between the two pins (see attached photo).
G'Day clockboy,
Thanks for responding.
The end stud is tight and the the regulator adjustment arm is actually slightly offset compared to most other pocket watches I've seen (see attached photo).
I've placed the movement in its case and run it overnight. I notice now that what appeared to be a reverse in the regulator response might just be a case of the movement "settling in."
It's a very "low end" movement. The large jewels which appear in the first photos are just for "show." In reality there are no jeweled pivots in the whole movement. The big red rubies on the top- plate are some sort of end stones whose sole function was probably to fool the buyer. Even the balance wheel pivots are just metal on metal. I'm guessing the movement was manufactured in Istanbul, Turkey in the early 20th century. A fairly rugged, rough piece of work, but definitely not a precision instrument.
Thanks again,
Rob
FNQ,Au
You need both parts of the regulator and in line in order for it to work properly. The hairspring should be free inside the regulator pins and able to move freely no matter what position the regulator is at. This is not a compensated balance wheel so time keeping will not be spot on.
G'Day oldhippy,
The hairspring is free inside the regulator pins. I did close the gap slightly as it initially appeared too wide.
As can be seen by the last photo I posted, the the regulator was manufactured with the index pins offset from the indicator pointer. It is a bit of a "mongrel" of a movement, but it does seem to keep reasonable time... so far!  :)
Thanks,
Rob
FNQ,Au
G'Day nickelsilver,
No timing machine, just "eyeball and ear." I'm afraid my methods are almost as crude as the movement itself!  :)
The challenge was mainly just to get the old Turk running again and the accuracy somewhere in the ball park. The bloke that owns the watch has never seem the thing run at all.
Thanks again,
Buffo
FNQ, Au
7 minutes ago, Buffo said:
G'Day nickelsilver,
Thanks again,
Buffo
FNQ, Au
Ok, well, this thing could vary massively in rate over a period of hours and certainly over 24 hours. So it might be running a couple minutes/day fast fully wound and several minutes slow after 12-24 hours. Not figuring in how it behaves in different positions. So it is probably the case that the regulator is working correctly, but the watch is very unstable.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
    • ha ha looks like a WMD.....you know I want one now
    • Sorry to reopen a necro-thread (long dormant) - I have a Seiko Kinetic 5M42A that needs at least one coil, possibly both. Anyone know of any sources?  The usual fallback of eBay has failed me - there are people selling coils, but not the ones for this movement (which was apparently a very popular movement, used in Seiko and Pulsa branded watches.) The coil numbers are: 4002 516,  and 4002 519 I'd also love to find a source for spares of the screws used all over this movement - they're Seiko PN 0022 247 Thanks! (Moderator - if this should be a new thread, please do feel free to tell me, or drag this one into a new thread.) Don Eilenberger
    • Hi a read what you told me  but a still can't understand how to tell what way do you mean when you said the shape example?
    • I didn't take it apart until after you kindly explained its function! In fact mine doesn't work exactly the same way as described in the link OH provided in that it's not the whole block that moves but just the internal spring & its support. However, the 'franken-spring' I've cobbled together pending the right one turning up is, it seems, too thick to slip through the join in the two halves of the block as the mechanism is activated....
