Bergeon 6122 Trimming Tools
My son occasionally helps with house clearances. During a recent house clearance a box of watches was found (98% quartz crap) apart from a nice Casio & Seiko nothing of note, apart from at the bottom of the box was a box containing Bergeon 6122 tools. After some search on the net found that they are sold as Bergeon 6122 Trimming tools, tools for quartz trimming.
Has any of you guys any ideas what quartz trimming is !!
