Hi guy’s! Can anyone help me find a watch stem for this Caravelle watch, the movement is marked N3 without stripping the dial off the watch!IMG_0024.jpg
Well most caravelle  automatics of that vintage  were made by A. Schild. If you look  in the vicinity  of the balance wheel  you should see a maker's  mark and a number. If I am correct  it will  be a shield with the initials  as in it or possibly  as/st depending  on the vintage. You will  also see a number. Typically  4 digits. This is the designation  of of the maker and type of movement..then do an Ebay  search. You will find it. The n3 is a year of manufacture code..n for  1970s 3 for the year...or 1973
Edited by yankeedog
Hi Under the balance there is just visible the logo of ASchild  (AS) and the number either 2088 0r 2066 having looked up the numbers there is only a sheet for the 2066 so I have attached that. It will give you the stem number for that movement. hope that it is of use.
AS 2066.pdf
    • All watches are repairable a few oven duff tools knowledge skills. But I was just agreeing that it be easier to get a movement.
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
