Regulator not changing rate
Lc130
  I think this HS completed with the wheel, dose not vibrate to the right frequency/ beat.
They are said to be incompatible.
That can happen, if you somehow put the HS on the wrong wheel twice.
Also, are you sure if the two movements beat the same?
The donor movement is stamped 115/1.  Same as the other.  If I am reading this correctly, Ranfft describes all bifora 115 as 18000.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Bifora_115_1
Thank you for the help!
Charlie
Just as a reminder on modern balance wheels the hairspring is vibrated to the individual balance wheel. That's why when you look at spare parts list for modern watches the hairspring is not considered a separate component. In the days of American pocket watches the hairspring was separate but that's because they had timing screws to allow you to match the balance wheel to the hairspring.
Then if moving the regulator and it has zero effect that is because the hairspring is still touching something it's not supposed to be touching.
 You are not getting the right beat. Either HS is touching something, or the balance+ HS dosn't generate the right beat.
If balance complete produces right beat in one 115/1 bifora, it also would in other 115/1 bifora movements.
If balance complete ran right in donor movement, how come you don,t rebuild the donor.
Touching shortens the operating length of HS, thence,  runs balance fast and amplitude decrease so high amplitudes you are seeing reasonably  dismisses"  touching "
Good amplitude can only come about by strong impulse, which impulse can be generated by strong MS or strong drop of pallet jewel, you are seeing high amplitude at low wind. So you either got a massay ferguson MS in the barrel or pallet is positioned wrong, banks are solid and look undamaged, that makes pallets or fork  suspecious .
Charl
Beat would be 18000 per hr with correct HS. Mount on different HS , the  balance  complete produces different beat.  Two HS off of two bifora 115/1 are of the same CGS , not neccessarily same length,  We presume the HS you have belongs to bifora 115/1 based on your say, that it looked alright on TG at first.
I have the donor HS on the original balance wheel.  It sounds like they are not compatible.
At this point it appears that I have two options.  Fix the bends in the original HS.  I've tried and only made it worse.  The other option is to order another balance assembly.  I had previously asked which one to order in this post. Is the third line the correct part?
How about replacing the fork.
Most anyone would ruin HS without good magnification, light and fine tweezers.
A new balance complete may finish this project with success, but in a way robs you of the chance to practice ( the route to skill) to build a balance complete, find faults, sort out a bent HS and learn. I am not getting tired since I am just talking.  Ha ha.
Hi Charlie,   Sorry for late response. Internet, internet,  can,t even read previous posts on this thread. Was the movement running slow or fast? If slow, depending on how slow? You may have a HS compatible with the wheel, in which case,  one option is to go for vibrating the HS with the wheel.
You have successfully transffered this HS couple of times, that is all the skill vibrating requires.
New balance complete is the last option.
Regards joe.
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
