Hi guy’s! As anybody used glue to fit these tubes back into there watch cases! I’ve got a screw down tube that should be friction fit, its loose in the body & keeps popping back out when i pull the crown out to alter the time!
If you slightly, and I mean slightly,distend the tube ( with a pair of pliers or vice ) it should friction fit with some strong adhesive. You could also try cooling the case and heating the tube to expand it then friction fitting it.
There is a way to mark the inside of a hole to help it grip by inserting a cutting broach without rotating to introduce some raised burrs.
You can also possibly spread the pendant tube on the case side if you are careful.
Are you sure it is the correct tube. When I have fitted they are just friction fitted. If just a snug but not a tight fit using loctite will work.
Thanks for the reply mate! Which Loctite glue would you recommend i use mate! Cheers!
You only need a medium strength such as the 270, or 290. But any of their range should work fine providing everything is grease free.
Hi clockboy! I got some locktite 680 & its worked like a treat mate! Cheers!
    • All watches are repairable a few oven duff tools knowledge skills. But I was just agreeing that it be easier to get a movement.
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
