Received and stripping my first jump hour.
The movement is no trouble. A simple 1 jewel pin pallet but the date/minute/hour (from the outside in) wheels are not budging. (Central pivot for seconds hand).
I suspect it has to be pulled off something akin to a cannon pinion but this being a particularly nice watch I want to wear I don't want to risk damaging it.
It's a Trafalgar Instantime.
Any pointers or ideas would be gratefully appreciated.
Thanks.
Yes, the seconds are friction fitted and can be removed using a pair of hand levers or .80mm screwdrivers inserted into the small slots seen in the picture.
Apply steady,  upward pressure...not too much because the seconds disc may warp if you push up too hard. Slow and steady. Here a link to a jump hour overhaul I did a few years ago
  • Thanks 2
Thank you, this gives me a bit more confidence to attack it again tomorrow.
I'll take a look through your service link.
Much appreciated.
Have taken a look through and that is perfect for my question. It looks to be near enough the exact same movement, though yours is a bit posher, it has a jewelled pallet fork pivot. :)
thanks again.
Edited by m1ks
Huge thanks to Joe above for the centre wheel removal pointer. Much appreciated.
Watch serviced and ticking away nicely with acceptable accuracy for this movement.
Collectible piece.
3 hours ago, Nucejoe said:
Wow, this variant of bfg866 is ultra rare, the crytsal, dial.
Yes this one has three mag windows in the crystal...I used to have one of these but sold it a while ago.
J
    • Its good to understand how and why demagnetisers work. These two pieces of text explain in basic terms how ferrous metal is affected by magnetism and why they can retain some of those properties.  The cheap demagnetiser is actually a magnetiser,but is used in a way that can remove the weak magnetic properties that a steel has gained through magnetic field exposure.
    • Yeah, agree on the rotation thing - I'll use this as my work beater, and rotate between the others outside of that I think.  The 'problem' is with these that in many cases the parts are worth more separately than in a bad example: assume the bezel, dial and movement the same seller is getting rid of came from the same watch... If he sells them all he'll get a similar price to a really good condition example.  There's a good side to that though - it means you can often find the odd bit you need. And I paid less for this case and crystal assembly than I did for a crystal and dial holding ring I bought for another project, so there's still value to be had occasionally.
    • Cheap ginger counters will tell you if you have radium, but don't waste your money and don't worry about it.
    • Nice rescue. I like when a few with heavy patina are worn in rotation with nicer watches of a collection. Frankens, too so long as they aren’t passed off as something else. My experience with these Seikos is they tended to disintegrate on their own so finding correct parts to put an original together is near impossible…
    • Some answers from my view screwdrivers - if the bodies are ok for you maybe only look at changing the blades if possible, probably 100 and 140 first. loupes - 3-3.5 is what is normally recommended for disassembly and assembly, 10x for inspection  digital microscope - not great for working on movements as there is no depth perception, great for inspection and taking photos to post here 😀 automatic oilers - a bite marmite/vegemite at times, various opinions, some swear by them, some use them only for certain jewel settings others don’t care for them at all. They are not at all necessary, the usual alix etc. ones are fine and you don’t need to spend a fortune. They are very subjective though, you may end up making your own from a needle and peg wood because you like it just so.   can’t help with the Geiger counter, I’m one of the ones who don’t get freaked out about it. There is a legitimate concern, however as long as your not licking the dials/hands, or snorting the degraded old powder you are likely to be absolutely fine.   Tom
